is a boost fooler needed
Old 06-23-2009, 01:29 PM
benroberts3605's Avatar
with my mild programer and mach 1.6s is a boost fooler needed to keep a check engine off
Old 06-23-2009, 02:19 PM
98.5Hotrod's Avatar
I think most programers do boost fooling, I may be wrong. I would go to the Superchips website and see if they have any info.
Old 06-23-2009, 02:41 PM
Ill look into that I never thought about the programer doing it
Old 06-23-2009, 09:32 PM
DodgenIt's Avatar
I know EDGE and Smarty do also. But I dont know how many others do. With chip and sticks it'd prob be a good thing to have.
Old 06-24-2009, 01:20 AM
Fishin2Deep4U's Avatar
Do the key trick and check for codes. It may be unrelated to the programmer of boost.
Dave
Old 06-24-2009, 03:10 PM
Ph4tty's Avatar
If you're going to run bigger injectors you might as well get something that does boost fooling and get a j-hook for your turbo. I don't think overboost codes will cause a CEL.
Old 06-24-2009, 07:49 PM
what is a j-hook for the turbo
Old 06-24-2009, 11:36 PM
DodgenIt's Avatar
Its a hook that latches onto the waste gate to keep it closed longer instead of opening at the stock 20-21 lbs mark.
there are a few brankd out there here is one.. http://www.xtremediesel.com/bullydogj-hook182555.aspx
Or you could always put a turn buckle on it. It'll do the same thing. Just be careful you dont tighten it too tight at first. Dont go over 30 lbs with our hy-35 turbo just to stay safe.
Tighten a little, run around the block and test, tighten test etc etc.
Old 06-26-2009, 03:12 PM
hamilton71801's Avatar
Superchips does not do boost fooling but here is my story. I had a 3715??? SC, a BD boost fooler and J hook. Everything worked great, no codes and 26psi of boost. My fooler went out and started throwing codes so I took it off(fooler). I reset my codes with my SC and it never threw an overboost even though I was hitting 26psi so no, you don't need a fooler....at least I didn't.
Old 06-26-2009, 05:06 PM
Yes, you need some kind of boost fooler to exceed 20 or so psi.
Either built into a box or standalone, the factory ECM is trying to defuel right now.
You might look into an EZ or small Quad box if you don't want a bunch of power, but you will get the boost fooling and a small kick in mileage from the added timing.
Dave
Old 06-27-2009, 10:04 PM
DodgenIt's Avatar
I agree, Edge EZ or small quad. Gotta say I love my J/A though. The EZ just gave me the power bug and only held me over for a year brfore I had to have more haha.
I see in your sig, BenR, it says.. superchips for now.. here's your chance to upgrade
studio5o
12-07-2013 09:24 PM
Killdmycobra
11-12-2010 05:15 PM
fade94
08-04-2010 06:44 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
TE-44
12-15-2003 10:06 PM
Quick Reply: is a boost fooler needed
