boost foling with smarty
Old 07-27-2009, 07:18 AM
Farmall Power's Avatar
I have a smarty s06 pod, is there setting in there to do boost foling or do i need to buy a boost fooler?
Old 07-27-2009, 07:37 AM
rebel102285's Avatar
I'm not sure what the others will say but I have the same tuner as you and mine does NOT boost fool.... I have the option for wastegate on and wastegate off, but neither changes the level of boost i run at WOT
Old 07-27-2009, 11:42 AM
DTR 1st Sergeant
soulezoo's Avatar
Boost fooling is not intended to raise boost. Boost fooling is intended to keep your ecm from throwing an overboost code at higher boost levels that you may reach when using power adders like a smarty. Your smarty DOES boost fool to about 44psi. (roughly the limit at which the MAP sensor will read)
If you want more boost you need more fuel to spin the turbo harder... If you have reached the practical limit of your turbo, then you also need a bigger turbo. Boost fooling DOES NOT mean you will make more peak boost... just that you won't throw the overboost code in its simplest explanation.
Old 07-27-2009, 07:19 PM
no_6_oh_no's Avatar
Originally Posted by soulezoo
Your smarty DOES boost fool to about 44psi. (roughly the limit at which the MAP sensor will read).
Smarty does not boost fool, it remaps the boost tables to the limit of the MAP range.
Yes, you will need a boost fooler for several reasons. The Smarty will allow you to push beyond 44 psi easily on the higher tunes, and, a lot of trucks the WG off does not work and you will not get over 30 psi of boost.
Get a Quad fooler for about $75 and you will have a 40 psi limit which is about wher ethe stock turbo is done and you wil never have any boost codes.
Old 07-27-2009, 07:38 PM
Sniper05's Avatar
What do you do when you buy a aftermarket charger, do they make a plug that you plug into the electronic wastegate so it doesen't throw a code? Or is that a Boost fooler?
Old 07-27-2009, 07:42 PM
deathracer's Avatar
Would using a boost fooler also benefit if you are just running a Smarty Jr?
Old 07-27-2009, 07:55 PM
no_6_oh_no's Avatar
Yes.
No, that is just a resistor to keep the ECU from thinking the electronic WG control is bad. A boost fooler hooks to the MAP sensor betwen it and the ECU. It clamps the voltage so the ECU never sees the higher numbers.
Old 07-27-2009, 07:57 PM
SCCSURF's Avatar
No, I tried and it does nothing but cool the EGT's a little.
Old 07-27-2009, 08:02 PM
no_6_oh_no's Avatar
Thats not a "benefit"??
Old 07-27-2009, 11:01 PM
bigwheels94's Avatar
This has me thinking. I wonder if I would see more boost with my setup if I ran a boost fooler? I think my WG on the HTT is set to 38#, & but if I push it real hard I can get it to 42#.
Old 07-28-2009, 02:09 AM
snowmanx's Avatar
So running a boost fooler does what? On my smarty at 5 it only spikes to about 32#, how do you get more boost. More air cool the EGTs? Wouldn't that increase the heat?
Old 07-28-2009, 08:12 AM
no_6_oh_no's Avatar
Wouldn't change a thing for you if you have a bost elbow and the WG is not contrlled by the ECU. It will stop codes if you push over 44 psi.
I easily see up to about 42 psi with Smarty on #5, then the boost fooler is opening the WG to keep things in check. DP is out of sight on a 60 lb gauge at that point though.
The fact you can run 35-38 psi where you would only see 30-32 cools the EGT's down so they don't spike so high under a load.
Old 07-28-2009, 04:45 PM
snowmanx's Avatar
So I guess the question begs why am I not seeing higher boost levels? Is something wrong. I have seen boost pressure as high as 34, but that's under a high load and then only for a few seconds before it starts to come down.
Thanks again, sorry to high jack your thread, just trying to learn here.
Old 07-28-2009, 05:56 PM
no_6_oh_no's Avatar
Smarty doesn't boost fool, it just remaps the boost tables so the engine won't defuel and throw codes when it hits about 36 psi (I think thats what the stock setting is), but, thats not what controls your boost.
Boost is regulated to the factory setting by the ECU controlling the waste gate. When it hits the preset level the WG opens and boost quits climbing. Smarty has the WG Off option that will just turn off the control, but, it doesn't work on some trucks and it is a bit dangerous because there is NO boost control now.
If you have enabled the WG off in the Smarty options then yours is one of the trucks it doesn't work on. If you have not enabled it, try it and see what happens but watch the boost.
Old 07-28-2009, 08:01 PM
snowmanx's Avatar
Thumbs up
Gottcha! I enable it and it didn't do anything, so I guess I've got one of "those" trucks! lol Don't know if that's a good thing or not.
Thanks no 6, you're a weath of info!
Quick Reply: boost foling with smarty
