Boost elbow
Boost elbow
Just wondering if there is any possible way to put the boost elbow on my stock turbo for more boost. I already have the J-hook but the spring is getting weak from the heat. Any thoughts would help.
That would not work. I made a mistake anyway the line is metal not plastic. I have heard of guys pinching it but i'm not sure i wanna take thatchance of over boosting and blowing the head gasket.
https://www.dieseltruckresource.com/...58&postcount=6
I have some long drill bits and drilled a 1/4" hole in that flange on the turbo for a neater install but if you need a bit thats about 12" long.
Turnbuckle works way better than the j-hook. I hit 32 lbs all day long till 4th gear then 35 lbs. EGT's are lower too. With the j-hook i was only hiting 24 lbs and it was adjusted all the way up. Thanks guys.
heres wat my stock turbo looks like with the boost elbow on it link:
http://i223.photobucket.com/albums/d...1/IMG_0462.jpg
I used a boost controller you could cut your metal line and put it in line you can then mount it in a easy to get to spot to adjust. Heres a link to the one I got.
http://www.boostcontroller.com/index...26category%3D5
