Boost Elbow
Old 06-11-2007, 08:17 PM
3592788's Avatar
Question Boost Elbow
IS this what you need to increse boost on 03 cummins thanks http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
Old 06-11-2007, 09:11 PM
Rob C's Avatar
yes .........
Old 06-11-2007, 09:42 PM
2003Ram's Avatar
That's it. It will allow the 22-26 stock psi to go to ~ 34psi.
Old 06-11-2007, 09:58 PM
03qclb5spd's Avatar
Did you buy it already? I have one that I never used because I got a bigger charger. PM me if you are interested.
Old 06-11-2007, 10:03 PM
stock03's Avatar
Can't they be used on after market turbos? I have a SuperB, and a guy from ebay (who sells them) said it help out. I never bought it though.
Old 06-11-2007, 11:47 PM
03qclb5spd's Avatar
I highly doubt it. I don't trust a lot of those e-bay guys that claim this works and that works on these trucks and those trucks. I'm sure a lot of people have been disappointed.
If you're ever in question, call the manufacturer.
Old 06-12-2007, 12:29 AM
Smithereen's Avatar
I`ve got one.Works great as long as your module does boost fooling.
Old 06-12-2007, 12:30 AM
Rob C's Avatar
Most aftermarkets are already set up to make max boost for that given brand, adding one of these won't help.
Old 06-12-2007, 07:11 AM
MikeyB's Avatar
I have one also. 32-33psi with a boost fooler (EZ or the SMARTY).
MikeyB
Old 06-12-2007, 08:49 AM
stock03's Avatar
No kidding. Anything to make a buck. Once I have my boost gauge, I'll know what my numbers are.
Old 06-12-2007, 12:03 PM
DTR 1st Sergeant
soulezoo's Avatar
Despite all the tinkering-- I've got the boost elbow, and it is completely closed. Got a quad boost fooler. Have Smarty Beta 4.4 loaded. Still don't ever see over 25 psi.
Measured by mechanical Auto Meter gauge at the intake horn. Oh well...
Old 06-12-2007, 02:00 PM
ropnjessi's Avatar
I thought the Smarty had a built in boost fooler?
Old 06-12-2007, 03:07 PM
Rob C's Avatar
Try pulling the boost fooler out and see what happens, I have pretty much the same set up and I get 34-36 psi out of mine.
Old 06-12-2007, 03:44 PM
2003Ram's Avatar
I see 34psi under load.
Towing 10-11k on a 6-8% grade
60-65mph in 3rd (48re)
EGTs = 1200* pre-turbo
Other wise, it reads less than 25 psi. Generally around 10 psi on cruise control running empty.
Old 06-12-2007, 06:41 PM
lniemeyer2's Avatar
I thought on the 03-04's that all the boost elbow did was increase egt's and that the extra amount of boost wasn't benificial it just blew hotter air.
Quick Reply: Boost Elbow
