bombing a medium duty
Old 12-01-2003, 07:49 PM
jeffket's Avatar
Just wondering if any of you have bombed a medium duty? I run a freightliner fl60 with a 215hp cummins that I would like to upgrade a little. Any suggestions on a heavy truck pulling about 25,000 total weight all the time.
Thanks,
Jeff
Old 12-01-2003, 08:13 PM
Re:bombing a medium duty
First thing I would do is get gauges. I was going to try to get my work truck uprated (330 hp is available) until I saw the EGT under load. I don't have room for more power pulling a hill in the summer with a full load, so I'm stuck at 300 hp. Make sure you have some elbow room on the EGT gauge before you make any plans for more HP. I'd put a freer flowing muffler (racing muffler would do) and a resonator to keep it unrestricted but not too loud. It's not too hard to control the noise of a straight pipe cruising around in an empty pickup, but in a heavily loaded medium duty it's going to be loud all the time if you straight pipe it. (When the flex pipe on mine failed, it was ear-splitting under load. Sounded great to me, but that's just looking for a ticket.) Summit has the muffler, Berube's is a source for the resonator. If the EGT's aren't bad with a good load on the truck,get bigger injectors. An HX-40 would help keep the EGT under control, too. Is this thing a 12 valve or a 24 valve?
Old 12-01-2003, 10:02 PM
KATOOM's Avatar
The ISB in these trucks is a medium duty engine and lots of these people here pull around that much weight often so I dont see the difference of application.
jbm
08-22-2005 10:52 PM
jlasich
05-05-2005 05:55 PM
system-f
10-15-2004 05:36 AM
racermatt2606
07-14-2004 04:23 PM
1sttruck
10-20-2003 05:33 AM
Quick Reply: bombing a medium duty
