'Body' code look up
Old 01-17-2008, 05:39 PM
LFD2037's Avatar
Question 'Body' code look up
Do ya'll know where I can look up 'body' codes. My truck is throwing 3 of them & I would like to know what they are for. The body codes are seen when you hold down the odometer button & turn the key on. TIA
Old 01-17-2008, 05:49 PM
LFD2037's Avatar
I did a search but none of the codes I have are on the list I found. My codes are 5 121, 282, C 447. Does anyone know what these mean? I am having the wierd turn signal crap going on.
Old 05-16-2009, 07:24 PM
BroncoAZ's Avatar
Did you ever find an answer for this? Mine is pulling the same codes. The check engine light just came on at 29K.
Old 05-16-2009, 08:08 PM
Catmandoram's Avatar
I have a code book. The "C"is the chassis, the first number 4 is the Aux.Emission controls
& 47 is identifying spec. malf. section of the system. My book doesn't show "C" codes. Just "P".
Old 05-16-2009, 09:27 PM
6.6lEater's Avatar
I just checked all data lfd the closest thing that I found to any of those codes was c1447. Front sway bar disconnect but I dont think you are looking for that one. Nothing in all data even comes close. But then again info from all data is like taking dancing lessons from a retarted kid.
Old 05-17-2009, 12:55 AM
DaveB.inVa's Avatar
Whats your turn signal doing?
There is a thread on here concerning the turn signals flashing one way when you're turning the other. It involves replacement of the turn signal unit on the steering column.
Old 05-17-2009, 02:00 AM
Clane's Avatar
What's this little deal???
Is this the same as the key trick as the pre OBDII trucks?
How does this one work?
Old 05-17-2009, 10:11 AM
tryNto's Avatar
lists of codes > http://wiki.dieseltruckresource.com/wiki/Computer_codes
i didn't see what you posted...
Trooperthorn
01-07-2011 12:55 AM
jj3500
07-12-2009 03:59 PM
Dodge@KY1997
21
02-04-2007 08:00 PM
97CTD
03-17-2003 09:12 AM
Quick Reply: 'Body' code look up
