Bob/Marco 700mi from home w/ problem
On both the TNT and regular revo, if I load the default torque management I have no cruise control. If I load level 4, I have cruise. Only problem is I don't want to pull my 15klb 5er on torque 4. Anything you could email me to try?
That is weird. I just went and set mine to stock TM with the TNT software and my cruise works. What about torque level 2? That shouldn't be too harsh on anything.
You didnt turn off the shift defuel did you? I guess it would be obvious with your drive selection letters blacked out. Just a quick idea.
Return it to stock, make your changes, and then reload. See if that may help.
Good luck!
Good luck!
I don't know about the switch - but maybe. Here's what it's doing. The on/off works and indicates on the dash. Then I can set the cruise and it will hold anywhere from a few seconds to a couple minutes and then suddenly disengages. Then it will not reset. I can turn the truck off and restart it and then it will set but with the same results.
53 willys
03-13-2008 10:45 PM
blcoonrod
53
02-23-2007 03:01 PM
HeberRam
11-18-2006 01:22 PM
Cmullen
10-28-2006 11:50 AM
jonesm8
19
10-21-2006 03:07 AM
