On Board Air
Old 11-18-2003, 10:38 AM
hellotbone's Avatar
On Board Air
Installed the kit from onboard air on the weekend. A truely superb aftermarket upgrade that fit first try no mods a direct bolt on. I can fill my (2) 9 gallon tanks in about 1:30 seconds to 200 PSI. This thing really pumps air. To anyone interested the kit is about 1 hour installation tops and has everything you need I did the installation in my garage with basic hand toold. An impact gun is required to remove the alternator pulley thats it.
A great kit.
Old 11-18-2003, 01:30 PM
rattle_rattle's Avatar
Re:On Board Air
[quote author=Jamie link=board=7;threadid=22564;start=0#msg210997 date=1069173539]
A great kit.
[/quote]
Are your tanks attached to the truck or are they portable? I'm toying with the idea of adding an air system to mine but have no room under the hood for storage tanks.
Old 11-18-2003, 05:37 PM
patriot pearl blue's Avatar
Re:On Board Air
Do you have any pics or a website where we can see how this works?
i assume the pump gets turned from the serpentine belt to build air right?
does it have a clutch so its not turned all the time?
thanks for the info
BW
Old 11-18-2003, 05:59 PM
jfpointer's Avatar
Re:On Board Air
[quote author=patriot pearl blue link=board=7;threadid=22564;start=0#msg211126 date=1069198667]
thanks for the info
BW
[/quote]
http://www.onboardair.com
The kit for the Nippondenso alternator is new; he didn't have that one available last time I looked. Uses a clutch and a V-belt that I'm pretty sure runs off a replacement for the alternator pulley that Jamie is talking about removing.
Old 11-19-2003, 07:39 AM
hellotbone's Avatar
Re:On Board Air
Onboardair is where it is coming from. It runs off the alternator pulley with a new pulley with a V belt on the outside.
As for the alternator I just had to grind a small alumamim fin off the alternator to make it fit. Everything else was bolt on.
Old 11-19-2003, 09:42 AM
southernsmoker's Avatar
Re:On Board Air
Why don't they have one for the 12 valves??
Old 11-19-2003, 10:48 AM
hellotbone's Avatar
Re:On Board Air
Dunno u might have to call em up and see. Maybe no one has donated a truck yet?
herb
07-18-2008 08:25 AM
durasmack
10-04-2005 09:52 PM
diesel_work
08-30-2005 05:00 PM
firestorm
20
11-09-2004 06:37 PM
zookeeper
02-23-2004 09:05 AM
Quick Reply: On Board Air
