Bluish/White Smoke...
Old 03-11-2007, 12:38 AM
Common's Avatar
Appears when first starting in the morning and taking off...
Or when the truck sits and idles for a while...
Clears right up after a puff...
What do you guys think?
No cat, so that might have been trapped if one was present?
Old 03-11-2007, 07:05 AM
berner's Avatar
Slipped timing and/or low fuel pressure will cause blue/white smoke.
Old 03-11-2007, 09:22 AM
Common's Avatar
Just that tiny bit?
Old 03-11-2007, 09:55 AM
TIMMY22's Avatar
when the engine is warming up, a little white blue smoke is normal especially in cold temps. also, a little white blue smoke is normal when you first get on it after extended periods of idle.
Old 03-11-2007, 11:49 AM
Box5's Avatar
yea, i confirmed this with my nieghbor, he's a retired diesel mechanic and said thats common with all the diesels he's worked on, and he's owned 3 of these cummins for personal use to.
Old 03-11-2007, 11:52 AM
Common's Avatar
You guys just constantly make my day!
THATS WHAT I WANT TO HEAR!
ITS NORMAL!
(thanks!)
Old 03-11-2007, 12:04 PM
Box5's Avatar
now for the good reassurance, how about you trade me ur nv4500? :-D lol
Old 03-11-2007, 03:22 PM
kd460's Avatar
I'm not saying you have a problem, but, my truck did the blue smoke at start up for the past few winters, and I assumed it was normal as well. Recently changed out lift pump, overflow, and fuel filter as pressure was getting low and with my miles on the truck it was about due.
No more blue smoke at start up. KD
Old 03-11-2007, 07:40 PM
Common's Avatar
You reset your timing?
Old 03-11-2007, 07:41 PM
Common's Avatar
Oh man...
LOL... you wish
I love it!
Old 03-11-2007, 09:06 PM
kd460's Avatar
Timing was reset awhile ago, still had the blue smoke even after the advancing timing. The new overflow and lift pump seemed to do it. KD
Old 03-11-2007, 09:30 PM
Common's Avatar
I think it may be time for me to run over the fuel system...
Thanks for the input.
Old 03-12-2007, 04:21 AM
kd460's Avatar
I also eliminated the multiple connection points on the fuel lines. I started with the steel lines along the frame, cut and flaired them, ran rubber lines from the steel lines at the fram up to the steel lines at the engine. That got rid of the braided sections with the push on connectors, and it got rid of the short solid steel tubes at the bellhousing at those connection points.
It now makes changing those lines allot easier, and any potential leaks from those joints. Don't forget the short rubber hose (90* bend) that connects the prefilter to the lift pump and use new sealing washers on everything. KD
Old 03-12-2007, 02:53 PM
turbo246's Avatar
ok i was driving the my 12 valve and it seems liks im losing top end power, so today i punched it and and it down shifted to seccond gear (4.10 ratio) and it poured out white/blue smoke and does not rev past 2250 rpm with it to the floor...whats wrong? it shoots out white/blue smoke every time you floor it now
Old 03-12-2007, 03:43 PM
Box5's Avatar
have you checked ur oil? You might have a coolant leak, headgasket leak maybe?
Quick Reply: Bluish/White Smoke...
