blown piston ring
Old 06-03-2008, 09:16 PM
2004ram2500's Avatar
blown piston ring
i own a 2004 5.9 and i think i blew a ring, the truck still runs and drives perfect. my buddy said it should be a 5k repair is this true?
Old 06-03-2008, 09:18 PM
scottsjeeprolet's Avatar
How did you come to that conclusion?
What are your symptoms, what's going on to make you think it's a blown ring?
Tell us more so we can help more.
Old 06-03-2008, 09:25 PM
Rpainter's Avatar
to just replace on ring should be less than 400 in parts that is if no cylinder wall damage. I lost a piston a few months back. I replaced the piston had alll decompressed and recoated,custom cam and springs. and had less than 2500 in everything.
Old 06-04-2008, 05:14 PM
dark smoke coming from the tube under the motor and its also burning the oil out
Old 06-04-2008, 05:37 PM
Spooler's Avatar
Hmmm, no way to tell. It sounds like an injector or something. Only way to know is tear into it. What you are saying dosen't make sense. If you are burning oil it normally comes out the tail pipe. Any blue smoke out the tail pipe? It will smoke out the vent tube, after working it hard, a little. Only way I can think of that will cause it to smoke out the vent tube is excess crankcase pressure and that is caused by a scored block, bad piston,or bad rings. Not the oil ring.
Old 06-04-2008, 05:45 PM
from the moment i turn it on the smoke never stops. and if the oil cap is removed it would smoke from there too.
Old 06-04-2008, 07:15 PM
04smoker's Avatar
I am curious?
killed300ex
01-15-2008 07:10 AM
HaulinBut
05-12-2006 03:06 PM
HaulinBut
05-04-2006 12:00 PM
CTD99
13
08-23-2005 10:55 PM
thumper 549
19
10-02-2003 05:38 PM
Quick Reply: blown piston ring
