Blowing oil everywhere
Old 04-22-2007, 05:01 PM
Ramdriver15's Avatar
alright i have been putting this opff for some time now, since i have increased fule flow and gained some power under the hood i noticed that the valve covers are spraying oil everywhere. I have heard about breathers on the covers? What would be the best route to fix this, and i also plan on replacing the valve cover gasket when i make this move.....
thanks for some input
Old 04-22-2007, 05:58 PM
clutch1's Avatar
might try checking your blowby tube you may need to clean the screen. not a fun project
Old 04-22-2007, 07:03 PM
i believ theblowby tube still works, the diff is covered with oil because i dont clean it... although i notice that there is never any oil drips so im guess low amounts of blowby
Old 04-22-2007, 07:05 PM
but with the breathers what is the best route to go???? any pics, or install instructions?
Old 04-22-2007, 07:34 PM
kawi600's Avatar
Check the vacuum pump? Might be pressurizing the motor
Spec is 8-25 inches mercury I think
Old 04-22-2007, 07:39 PM
how do i do that? and yeah, never even heard of testing the vaccum pump, so make me smarter lol
Old 04-23-2007, 11:49 AM
kawi600's Avatar
Put a vacuum gauge on the line where it comes up off the pump and goes into the first splitter. Im not sure 100% if youd see a bad reading if you were pressurizing the engine with it. Maybe pop open the oil fill cap and see if it is venting lots of air
Old 04-23-2007, 12:57 PM
alright now that is easier of a test, but would the breathers be a good idea?
Old 04-23-2007, 01:03 PM
Scramblinman's Avatar
They will just be somewhere else for oil to blow out of.
Old 04-23-2007, 05:44 PM
oh boy, lol then how do we fix the oil blow out???
Old 04-23-2007, 06:57 PM
infidel's Avatar
As said a vacuum leak will cause increased blowby.
Easy way to check for a leak is to shut the engine down, wait a few minutes and disconnect any vacuum line under the hood. If it doesn't hiss you have a leak. My rigs without leaks will hold a vacuum for at least a week without the engine running.
Old 04-24-2007, 04:49 AM
diesel don's Avatar
Oil problem
I know that each time i start the truck I can hear one of the vacuum servoes move from defrost, which is its default position. That would mean that there is no vacuum being held in reserve, it has always done this even after they replaced the vacuum pump at 38,000 because it was leaking oil not vacuum.
Old 04-24-2007, 04:27 PM
i have not had any more oil come out the blowby tube, but i have had increased oil being pushed out the valve covers, would this be cause by a vaccumm leak?
fearthedeere
07-21-2005 03:18 PM
herb
33
02-26-2005 08:53 AM
CCOUGHRAN
125
08-18-2004 07:23 PM
powerwagon440
04-29-2003 08:53 PM
Quick Reply: Blowing oil everywhere
