Blower fan problem
Old 08-05-2005, 08:34 AM
v8440's Avatar
Blower fan problem
Hi all,
The blower fan in my '98 ram only works on the high setting. I checked both fuses (the one in the dashboard and the one under the hood) with a VOM meter, and both are good. I tried substituting the blower fan relay for another relay with the same part numbers printed on it, and it still only works on high. What should I look at now?
Old 08-05-2005, 09:41 AM
99 cummins's Avatar
Just found my problem to, in between the fan and the center hump mounted to the bottom of the dash you will find a small plug. Unplug that and pull the two screws out of the plate, when you do a small ceramic block will pull out probably in chunks, thats what needs to be replaced. Gotta play twister to get to it.
Old 08-05-2005, 10:30 AM
v8440's Avatar
Oh, that must be the resistor that provides the lower speeds.
Old 08-05-2005, 11:30 AM
v8440's Avatar
Well, I pulled the resistor out, and it looks fine. It's not cracked or scorched. It could still be bad, and I can test it with my meter if I can get a pinout diagram of it and what the resistance values should be. Anybody got a diagram for it?
Old 08-05-2005, 12:22 PM
SilverRam01's Avatar
I just did this same thing.......
It's a relatively simple resistor. On mine, the crossover spring / clip near the base had come apart. I set it back in place, soldered it, reinstalled. Fan works now,.....and I saved about $50.
Old 08-05-2005, 12:47 PM
99 cummins's Avatar
$50 !!! I payed $13.00 for mine at Orielly's "excuse the spelling".
Old 08-05-2005, 01:54 PM
v8440's Avatar
I just went to a junkyard and got one. I haven't tried it yet, so I dunno if that's the problem. I'll go outside in a minute and plug it in.
Old 08-05-2005, 02:20 PM
v8440's Avatar
Ok, that was not the problem. It still only works on high. Now that I have two resistors, I got my VOM and compared the resistance of them. I put the probes on every possible combination of terminals, and got EXACTLY the same resistance reading between the two in every case, down to a tenth of an ohm. So, I think I can safely rule the resistor out. I'm beginning to wonder if the fan switch might be the problem.
Old 08-09-2005, 09:42 PM
99purplecummins's Avatar
it is normally 33 something.... your just lucky you have a son that works at an autoparts store
Old 08-10-2005, 07:35 AM
Geico266's Avatar
Same thing happened to me after I changed out the blower motor. I resoldered it and it works fine.
Old 08-10-2005, 01:21 PM
lglamb's Avatar
that spring clip was open on mine, but I thot it just
went to an unused spade connection.
Guess if I figure out where I put the thing, I'll re-solder
it and see what happens.
Thanks,
Lowell
Jim Lane
04-05-2020 06:03 AM
big jimmy
07-07-2006 01:33 PM
piperca
10-24-2005 11:32 AM
SilverRam01
07-11-2005 09:12 PM
Palmetto_kid
04-10-2004 01:26 AM
Quick Reply: Blower fan problem
