Block Heater Question
Anybody know if there's a fuse somewhere for the block heater - I've noticed the past two mornings when I go out to start the truck it acts like it was never plugged in at all. I double checked the power to the extension cord. It did start with no problem but turned over really slow like the engine was really cold (4 degrees here this morning) and the grid heaters were cycling on, which they never did before when the block heater has been plugged in. Do these block heaters ever go bad?
Mine also took a dump years ago. Can anyone explain how to replace the block heater cord? The block heater doesn't look like it comes off my 95 CTD. I can't see anything to put a wrench on?
A knurled collar (nut) holds the cord on the the block heater. Reach under there with your hand and feel around for the collar. It will usually unscrew by fingers only.
Yes they do go bad but not often. Those heaters in a genset usually last at least 3 years and that's on all the time. They have a thermostat but do get a good work out. If the element is bad, you might want to check the coolant and change it. If it ate through the element, oil cooler is next.
rjm022
12-11-2019 09:17 PM
SpeedyWS6
15
02-02-2011 07:22 PM
supersonictoys
11-08-2008 09:17 PM
modiesel
03-07-2008 10:44 AM
