blackstone report
Old 05-10-2008, 01:59 PM
motrapper's Avatar
blackstone report
i just got back a oil; report of 20 on potassium and it should be 11 they said the new egr some times runs up the sample but where could a new 07 5.9 with 13,000 miles be getting coolant from any thoughts
thanks
Old 05-10-2008, 02:03 PM
AH64ID's Avatar
post up the whole report if you can...
Old 05-10-2008, 03:09 PM
motrapper's Avatar
Blackstone report
Here is my report. Review it and let me know your opinion.
File Type: pdf
Old 05-10-2008, 04:26 PM
Foxborough's Avatar
Wait a minute on deciding on what to do. I had a simular problem last year.It appeard that there was an increased precentanged of potassium. Then, it suddenly changed to normal. I have been sending a sample after 4000 miles and change the oil at 7500 miles since. Now after two samples later, no problems. I believe it must have been from the sampling hose. (sorry for any spelling i do not have my normal spelling check on this computer )
Old 05-10-2008, 08:29 PM
Roperteacher's Avatar
My 07 5.9 currently has 26000 miles. Oil samples taken every 5000 and my lowest potassium was 0 and my highest was 7. Most were 5,6's.
Old 05-10-2008, 08:55 PM
AH64ID's Avatar
Well being a 5.9 you don't have a cooled EGR, so that rules that idea out... I am disappointed they even mentioned it, IMHO they should know more about the engines if they want to make comments like that...
Old 05-10-2008, 09:55 PM
dozer12216's Avatar
Three oil samples at $30 or so dollars a pop. Way to serious about oil. Run her out to about 10,000 miles and check for significant abnormal material in sample. Believe potassium is a oil additive to start with, not from something in engine, keep er rolling is what sample says to me.
Old 05-11-2008, 02:27 AM
Yes, Rotella I believe uses it as an additive. The way I look at it is $30 is cheaper than 12,000 bucks for a new engine. If you are having a serious problem, it does NOT take long for it to ruin something. For example, Fuel dilution. Or if you have a little fuel dilution at 5,000 it might help you see a problem WAY IN ADVANCE of it becomming to serious when the injector fully fails and fills the crank with diesel. I have no problem spending the 25.00 bucks every few months...
stang
13
09-20-2006 09:59 PM
Smkn600CTD
06-14-2006 09:47 PM
TexasCTD
04-20-2005 03:04 PM
VPI
09-18-2004 12:48 PM
Jerry R
08-12-2004 11:56 AM
Quick Reply: blackstone report
