Black Smoke, Performance Problems, help!!!
98 67k actual. Automatic Tranny
I just bought this truck, my first cummins, I am so proud. Anyway acceleration is poor, and it bellows out a tremendous amount of black smoke. I also notice that it will buck and jerk unless I have the o/d button pushed in. I got a gut feeling these two issues are the symptoms of a common problem but what??? Also this truck came from California. I am a mile high in Colorado Springs. Do I need to do anything to adjust it to the higher elevation?
Sounds like a truck I saw go through the auction here. Seems that the turbo was going out. It was dumping fuel in but no air so it bellowed black smoke and had no power.
I think you can buy a boost guage for around $30 and your truck is pre plummed on the intake for it.
Might be a good starting point.
Chass
ct
Chass
ct
Chass
ct
Chass
ct
Could a turbo go out with only 67K miles? What readings should I expect to see on the guage?
Black smoke is unburned fuel. What does your power feel like? Measure boost, as was mentioned. Check for loose/busted pressurized air hoses both before and after charge air cooler. Check fuel plate type and position, AFC screw position. Report back.
Man what a great site. Thanks for all the suggestions, I can do some of them but I am new to diesels. So some of the recommendations are presently beyond my mechanical aptitude. I am willing to do on the job training and I don't shy away from repairs so this will be a learning experience for me. See my next thread. Thanks
Also, tell us if you have a 12 valve or a 24 valve engine, the changeover to 24 valve was 1998.5.
The two symptoms you listed in your inital post are not necessarily related. Not unusual to have multiple unrelated problems, making diagnosis difficult. As you get familiar with the machine, you will discover what has been added/deleted. Hopefully it is unmolested and only needs adjustment and a maintenance catch-up.
it is a 12 valve. I don't know if I should have mentioned this earlier but who knows. It does have an exhaust brake hooked up but I didn't mention it because I didn't think it cause either symptom.
My guess is that you have an intercooler boot blown off. A boost gauge would tell you if you did or not, but, just pop the hood first, and make sure every clamp going from the turbo to the intercooler, and then from the intercooler to intake horn is tight with no holes. Good luck
Eric
Eric
RJOS
16
09-03-2007 09:19 PM
BuildingBoost
03-25-2007 07:46 PM
BlackSheep5
11-27-2006 07:52 PM
bensdad_canada
05-09-2005 10:56 PM
