Bilstien Shocks OR Dual rear
Old 08-10-2008, 01:26 PM
Ricks 2500 CTD's Avatar
I was wondering if the bilstien shocks was really that much better than any other shock out there ? I just put a superlift 6" lift and 3" body lift on my 2500 CTD with 37X13.50X17 tires 10" rims the truck looks KILLER. I also put dual shocks up front and single in rear they are rough country shocks my problem is the truck has a little sway side to side going down road ,would the bilstiens help this or would dual shocking the rear be enough? THANKS ANY HELP APPRECIATED. TRUCK IS 04.5 CTD 6SPEED
Old 08-10-2008, 01:40 PM
tritont's Avatar
a sway bar is what you need. Duals in the rear won't help the much. Hellwig makes one for our trucks that works well.
Old 08-10-2008, 04:38 PM
Are you talking about a sway bar for the rear?
Old 08-13-2008, 10:24 PM
crownsey54's Avatar
yes he is.
Old 08-14-2008, 12:56 PM
Cowhand's Avatar
Get rid of those crappy white body shocks.....and if your truck is primarily street driven, you don't need duals in the front. All that's doing is over-dampening the front and making the ride harsh. The only time it's acceptable to run a dual shock is if one of them is a coil over and the other is a bypass shock.
Do the Bilsteins first, you'll be amazed at the difference in ride quality and handling.
Old 08-14-2008, 01:49 PM
Megadeth's Avatar
Do any sites sell the 5100s for lifted trucks? Ive only seen them for leveled ones..
Old 08-14-2008, 02:48 PM
CrashCade's Avatar
I would say either buy new shock towers or make some yourself to work with and Eyelet to Eyelet shock and buy a nicer shock. Check out Thuren Fabiraction, KORE, Carli ther are some other ones too. They have shocks that are valved to the specifics of our trucks.
Also, it sounds like you are getting sidewall sway. Unless it is rocking from left to right mostly in the front. If that is the case, I would say that your track bar is not set right.
Just my .o2
ram4tow
ABDTR #5
13
11-17-2008 10:21 AM
FranticFire
06-20-2008 10:24 PM
OutHuntin'
20
05-11-2007 12:17 PM
SD-Dave
04-18-2007 01:38 PM
nonford
08-23-2004 08:27 PM
Quick Reply: Bilstien Shocks OR Dual rear
