bilstein shocks
Old 12-02-2006, 06:04 AM
msgtdave's Avatar
Question bilstein shocks
I have my new shocks, but by looking at the instructions, I am from the wrong country. What is the sequence of parts, spacer, washers, rubber bushings that go on top of the front shocks. I think the instructions stink.
Old 12-02-2006, 09:21 AM
dieselfan's Avatar
i had the same problem about 3-4 months ago and ended up changing the fronts about 4 different times, before i called bilstein and got the proper way.
i think it was flat washer, bushing(male) with nipple(facing up) then i stuck the shock in the lower control arm and through the top mount, then spacer. i then put female bushing then washer then i tightened it with and allen head and open end wrench (metric).
hope this helps, BTW this is for my 01 2wd.
edit: i forgot this, the spacer goes in between the bushings
im going to rotate my tires today, so i will double check.
dieselfan
Old 12-02-2006, 03:23 PM
AlpineRAM's Avatar
If the instructions are in German I can translate them for you.
AlpineRAM
Old 12-03-2006, 12:34 AM
biododge1's Avatar
sie verstehen, rechts?
Old 12-11-2006, 06:15 AM
msgtdave's Avatar
Smile shocks
Thanks for the reply. I have them on and there is a world of difference. The original shocks were trash(75000 miles). I also put the male rubber bushing on the botton facing up. Works any way.
Old 12-11-2006, 06:36 AM
dieselfan's Avatar
thats the right way, i had to call bilstein, i tried it a few ways and most of them made noise or it would let me tighten up the allen head too much.
which is wrong, if you did it right it will only let you tighten it up so much.
glad you got it.
dieselfan
Old 12-14-2006, 08:32 PM
FirstDodge's Avatar
How much were the shocks, and where did you get them? My '06 bottoms out really easy, and I need to do something. Only have 6K miles on it.
Old 12-14-2006, 11:09 PM
dieselfan's Avatar
this is where i got mine from for under $300 shipped( i dont remember exactly), this is the cheapest for bilsteins http://www.shockwarehouse.com/site/i...m?mode=results
Old 12-15-2006, 07:35 AM
dustoff's Avatar
check out eshocks.com. $64.95 for either fronts or backs for my '01. free shipping for order over $200. great customer service too.
Old 12-15-2006, 06:09 PM
atthepark's Avatar
another source
Genos garage (www.genosgarage.com) has them for $65 to $79 depending on year model.
Old 12-21-2006, 08:55 PM
msgtdave's Avatar
I got them from eshocks. Free shipping and also recieved a $10 off coupon on my first purchase. For the heavy duty shocks, it was $267 for all 4. Two rear shocks are easy to change. Front passenger side is a little problem. The drivers side will try your patience, but not too bad. Just pay attention to how the bushings and all were on the ones you remove.
RamDan03
22
01-18-2004 05:46 PM
Tackdriver
03-31-2003 10:53 AM
USMC64-70
03-13-2003 12:44 AM
MARKY MARK
02-09-2003 12:13 PM
99 cummins
02-01-2003 08:21 PM
Quick Reply: bilstein shocks
