Bilstein 5100 rattle???
Old 01-10-2008, 05:58 PM
Grocery Getter's Avatar
I installed four about 4 months ago and I know all the bolts are tight. Now from the right front corner, every bump I hear a rattle or clunk. ***?
I think it started after rolling into a driveway a bit quick, a whopping 10 mph.
Old 01-10-2008, 06:04 PM
DTR's 'Go to Guy'
vzdude's Avatar
I had a slight noise after putting them on, but haven't heard it in a long time. I was thinking that I didn't have the bushing centered, and it finally found its way. I would try to have someone rock the truck back and forth while you have a hand on the shock. Also pay attention to the sway bar link too.
Old 01-10-2008, 06:40 PM
firemansdiesel's Avatar
Recheck your lower shock mount on that side. Re-TQ it and make sure the bolt is in all the way. Common problem w/ the 5100 install.
Old 01-10-2008, 07:55 PM
"California Style"
mega-engr's Avatar
I have something like this on my stock truck. Dealer replaced the steering box and it seemed better, but after driving a while, I hear it still. It is the right front and only when going through a driveway at an angle...
Old 01-11-2008, 12:25 AM
D45
D45's Avatar
The lower shock mounting bolts must be torqued down, go 10-20 lbs past specs........
Old 01-12-2008, 04:39 PM
glowball's Avatar
You are probably feeling the slop in your ball joints. Our trucks come from the factory with up and down ball joint play. I noticed it big time with the addition of the bilsteins on my truck. Every little bump in the road I feel a thump up front. Isn't it nice??
Old 01-12-2008, 07:15 PM
stumpjumper's Avatar
also check the upper shock mount tower nuts. the 13mm ones make sure the tower is tight.....
Old 01-12-2008, 07:32 PM
Danderson's Avatar
'07 w/no thumps.
I've got an '07 with zero play or thumps in the steering. My neighbor's '07 is the same. I've got a Lorenz upgrade,he's got a Carli. I don't know if that matters. Stock,they were perfect too. Guess we lucked out.
Old 01-12-2008, 08:53 PM
glowball's Avatar
Think so? Go jack up the front end and put a bar under the tire and lift straight up. My brothers new one had up and down play right off the lot. The dealer said it is how their built. When I bought my new ones. The guy I got them from had nothing good to say about the dodge front end. I'll be curious to hear if you don't have up and down play.
Old 01-12-2008, 08:59 PM
Dodge states there is some play that is normal, but I never had a rattle/clanking sound do to my ball joints.
When I used to run the 5100 Bilstien shocks. I had a rattle/clanking noise like the original post when first installed. Re-torqued the bottom shock mount bolt like Lorenz told me. Problem fixed. No more clanking/rattle coming from the passenger front side.
Old 01-14-2008, 12:06 PM
Actually found the cause of the problem... Its the nut on the top of the shock stem. It was not tightened enough so the top bushing was allowed to wiggle.
So now, I torgued it down. Pain! Had to keep the allen fitted to the top to prevent the stem from rotating while I tightened the nylon lined nut.
I could not get the nut to tighten up the bushing to prevent all play. I can still wiggle it side to side. What can be done? The rattle is much better, but still there. Do I need some washers for spacing?
Old 01-14-2008, 01:29 PM
DTR's 'Go to Guy'
vzdude's Avatar
Buy the factory bushings from the dealer. I am not having trouble with mine anymore, but I did notice that the factory bushings were substantially larger.
Old 01-14-2008, 04:31 PM
Rednecktastic's Avatar
Yeah, I had to tighten mine all back up after a few hundred miles. Good as new after re-torqing them.
Old 01-14-2008, 07:23 PM
Ahhhh, factory bushings.... Good thing I kept all the stock stuff, just incase!
Thanks for the ideas and help!
MonkeyLips
21
04-22-2010 12:09 PM
mulepackin
07-04-2006 08:48 AM
JDGnut
05-01-2006 05:39 PM
kully560
03-12-2006 03:03 PM
schorb
09-11-2005 06:00 PM
Quick Reply: Bilstein 5100 rattle???
