biggest tires for stock dually
Old 04-02-2007, 10:42 AM
1baddually's Avatar
what are the biggest tires i can put on a stock 4x4 dually, i don't care if i hafta run spacers but i want a taller tire. been thinking about running 35's but will i hafta lift it if i go that big? would a leveling kit and a new rear block do the trick? i don't wanna get to high in the air but i wana a big tire.. thanks
Old 04-02-2007, 10:50 AM
dditt0635004x4's Avatar
you can runs 35's no problem with a leveling kit in the front it you look into my gallery you can see pictures of mine. The tires on my truck are 35"x12.50r17 procomp xtreme all terrains.
Old 05-07-2007, 01:10 PM
azdodge's Avatar
Is that with or w/o spacers in the rear?
Is your truck running 35x12.5rx17 with or w/o read spacers on the dullies????
Old 05-07-2007, 03:09 PM
Speed Shift's Avatar
You will need a 2" spacer between the rear duals if you run a 12.50 also.
Old 05-07-2007, 10:08 PM
goodeyesniper75's Avatar
i only needed 1" for mine with 35''s
sakisaki400
23
12-31-2006 10:17 PM
RedRam410
10-27-2006 03:25 PM
ridofpwrstroke
09-19-2006 08:55 PM
deere nut
06-16-2006 04:05 PM
1baddually
05-15-2006 06:29 PM
Quick Reply: biggest tires for stock dually
