What is the biggest injectors?
Old 11-09-2003, 08:35 PM
Captain Insane-O's Avatar
What is the biggest injectors made for a 12 valve and also curios on the 24s and were can I get them B-1 needs more fuel? 8)
Old 11-09-2003, 11:48 PM
PourinDiesel's Avatar
Re:What is the biggest injectors?
Well theres no simple answer.
Anyone can manufacture large injectors.
Problems though once you get above 150hp or so.
Is popoff pressures, atomization of the fuel (no dribble), balance, tip reliabilty etc.
Also having the proper air provided to burn the fuel that you are injecting is part of the equation (so you dont melt your engine).
If you are going EDM's.
J.R. Adkins, ATS, Don M, Buddha power.
Extrude honed:
ATS, Diesel Dynamics, Bully Dog, BD etc.
For a single B1 turbo, I wouldnt suggest over 150hp (for street app) unless you are going to run Water injection or Nitrous.
Good luck!
--Justin
Old 11-10-2003, 12:38 PM
BigBlue's Avatar
Bully Dog stage 8's or EDM Mach 6.5's. ;D
Old 11-10-2003, 01:40 PM
Jetpilot's Avatar
At least for 24v injectors Buddha Power's 12X12 injectors are capable of flowing the most fuel of any other injector I know of...... They are capable of flowing about 40% more than Bullydog 8's.
Doug
Old 11-10-2003, 02:20 PM
southernsmoker's Avatar
But what about the 12V's though? Also, what is the price range on those 12X12's?
Old 11-10-2003, 02:30 PM
Jetpilot's Avatar
As for the price of the 12X12's you need to contact John Russin (aka Buddha Power) at hummin99cummins@simcon.net or send me a pm and I will get you his phone #. He also makes lots of 12v components.....
Doug
Old 11-10-2003, 03:06 PM
BigBlue's Avatar
Hey Jetpilot, are those numbers in your sig drug free? How bout the 1/4 mile times?
Old 11-10-2003, 06:36 PM
Jetpilot's Avatar
BigBlue,
The numbers in my sig are running N20. My diesel only dyno number is 674HP and 12.3 in the 1/4. The 12.1 was on N20 last year with about 125 less HP than this year..... I haven't gotten to run on the juice at the higher HP yet.
Doug
Old 11-11-2003, 12:01 PM
BigBlue's Avatar
Wow. I'll bet that truck is a monster. Are you going to run propane as well or just N20?
Old 11-11-2003, 12:26 PM
KatDiesel's Avatar
[quote author=BigBlue link=board=7;threadid=22227;start=0#msg208488 date=1068573692]
[/quote]
Propane is useless at that level. Actually it becomes usless pretty much when you hit the 500 mark. This applies to Dodge only, because we can supply plenty of fuel. Since Jetpilot has a P-pump hes got plenty of fuel.
Old 11-11-2003, 01:04 PM
DTR Advertiser
Don M's Avatar
Take a bench grinder and grind the tip off the nozzle. Im sure it will satisfy your big injector needs.
Don~
Old 11-11-2003, 02:17 PM
BigBlue's Avatar
Can we say smoke?
Old 11-11-2003, 07:34 PM
yrusoslow2's Avatar
I have heard that propane is useless over a certain horsepower but I have always wondered why. Could anyone answer this question. And if I have in the mid 400 hp range right now should I even bother with propane.
Old 01-26-2007, 10:18 PM
Dazed&Confused's Avatar
Doug
Does he still have a website? I use to have the address but cant find it.
Old 01-27-2007, 05:55 AM
Mountaineer's Avatar
It used to be BuddaPower.net but the last time I tried to go there it said I had to have a Password or something.
Quick Reply: What is the biggest injectors?
