Biggest injector for a low pressure piston LP w/ maxed IP?
Old 01-10-2010, 02:06 PM
Oldschooldodge's Avatar
What are the biggest injectors that a low pressure piston LP can support? I am going to be in the market for new injectors, turbo, clutch, etc. in the next few months, but I don't want to run an electric lift pump. I just want to run the biggest injector possible, without running the IP dry.
Old 01-10-2010, 03:18 PM
1bad93's Avatar
well from what i know the limit for lp pistion lift pumps is around 400hp. so i would say 435s mabe 6x14. but im sure somone with more experiance will chime in.
Old 01-10-2010, 04:31 PM
feveree40's Avatar
just got some 6X16's and I can suck my piston pump down to 4 psi. With the stock non i/c injectors I could only bring it down to 9 psi. Hope this helps.
Old 01-10-2010, 05:54 PM
Rick 12v CTD's Avatar
If you already have a lp plp couldn't you upgrade to a high pressure one easily? Swap the lift pumps, add a regulator and you're done. Or am I missing something? I know it would cost a couple hundred more but at least you won't run out of fuel and it's all still mechanical.
rustybudweiser
10-23-2007 07:40 PM
highcountry
08-11-2006 05:44 PM
tomgreentwin
05-24-2006 08:50 AM
pwrtripls1
05-28-2005 04:00 PM
Quick Reply: Biggest injector for a low pressure piston LP w/ maxed IP?
