Big tires?
Old 06-19-2009, 10:37 AM
Dieselguy31's Avatar
Big tires?
Any body have an idea of how much rubber you can get away with under a 2006 dodge with 2" leveling pucks and 20's? It currently has 33's under it but I was wondering if you could put more. Thanks for the help.
Old 06-19-2009, 10:11 PM
nodakbassmaster's Avatar
I just put 275/65/20's under my stock height 06 3500 4x4 (lil over 34" tall)... so you ought to be able to get 35's with the pucks I'd say!
Old 06-19-2009, 11:18 PM
dan33900's Avatar
I have 35's on my 2006 with a 2" leveling kit.
Old 06-19-2009, 11:50 PM
Mocho's Avatar
You could stuff 37" but you won't be able to turn to well. Even 35" will rub slightly.
Old 06-20-2009, 07:47 AM
gsbrockman's Avatar
I have some Goodyear Wrangler SR/A's in LT305/60R20 (34.6" OD) on some 20x9 Ultra # 214's.
The wheel offset has everything to do with what rubs and what does not.
The Ultra's I own have 5.75" backspacing and +18 mm offset.
My truck is stock suspensioned with no leveling kit.
Greg
Old 06-20-2009, 08:44 AM
Thanks for all the info guys. I was hoping for 35's or 37's, so here's the next question, what amount of lift will I need for 37's?
Old 06-20-2009, 11:30 AM
Ridiculies's Avatar
To run 37's you need either stock wheels or H2's or something with similar offset and backspacing and a leveling kit. To run a bigger rim like 20's and 37's you will need at least 6" of lift. Can it be done with less lift sure, but the offset and backspacing of the wheel and even the profile of the tire will come into effect.
bigdrdge02
Off Road / 4x4
13
11-12-2010 06:01 AM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: Big tires?
