How big of a tire can I put on my 2wd Dually?
I have a 2006 Dodge Dually, CTD. I have the stock tires on it right now but it's time to buy some new ones. 98% of my driving is in the road but when I do tow or go camping I'm on dirt roads for a couple of miles. I've been stuck a couple of times, nothing too bad. (I try to be smart about where I am and what my limitations are.) I would like to get a taller/wider more aggressive tire on my dually. I just don't know what size and brand of tire I should look at. I like the BFG All Terrains. I heard they wear like iron.
My vehicle and load specs are:
2006 Dodge Dually CTD
4000lb Cab Over Camper
2300lb Car Hauler Trailer
3300lb Chevelle or Rock Buggy
Family of 4 and 3 dogs
Fully loaded I'm at approxiamately 18000lbs
Any suggestions on what tires will fit the bill?
Thanks,
Richard
Thanks,
Richard
Something like this BFG All Terrain LT265/70R17. Stock is 235/80R17.
http://www.4wheelparts.com/Tires/BFG...&t_pn=BFG55086
Or a LT285/70R17. Will I need a wheel spacer in the rear? Will they rub in the front while I'm turning?
I have 22.5 Alcoas with Hankook tires. The tires are 36.9 inches tall and all I had to do was install a two inch leveling kit to get proper clearance. Pics are in my gallery. Good luck in your tire shopping.
1 Post
if your lucky you mite get 34k out of the bfg's thats all i ever got out of them with my dually's. their real soft and seem to wear fast if you tow a lot and run the miles
I have 16's(02' dually) I did a conversion and all I had at the time was my original tires which were 265/75/16's and on the rear if I kept them aired at 65psi there was about a 3/4 inch gap. I did'nt load it. I had a slow leak on one and at times I could smell rubber burning. I only did it for about a week til I got my new tires in, 235/85/16's. I think it might have been better if I could have gone up to 80 pounds on the tire pressure but I have limits on my wheels as far as air pressure(65), not sure if that would have helped much, but still real close if your gonna load with anything.
I would stay with the stock tire size. The Goodyeat silent Armour are a good AT tire. I think the BFG AT/KO are alright too. The Goodyaer have a 50k warranty.
Bigger tires cause worse fuel mileage and other problems. These tires are already 31" tall, not small at all.
TonyB
08-02-2008 11:06 AM
CruisingRam
07-12-2008 12:34 AM
CruisingRam
07-11-2008 10:54 AM
TheRancher
05-21-2007 12:46 PM
bryan07
01-08-2007 04:46 PM
