How big and wide can i go
Old 08-21-2007, 07:55 PM
01DodgeDiesel's Avatar
I have a 01 Dually and i would like to get as big and wide as i can on it and it still look good. I have a leveling kit on it and i have the stock dually rims. Any info would be greatly appriciated.
Old 08-21-2007, 09:06 PM
kas83's Avatar
Someone posted on here about running 285's, and using a spacer between the rear wheels to avoid contact. 255's would work great, taller and thinner.
Old 08-21-2007, 11:26 PM
Ph4tty's Avatar
I've been told 255 is the widest for the 01-02 duallies without a spacer. A 255/85 will be a bit taller than your 235's but will also be 20 mm wider
Old 08-22-2007, 02:56 PM
Ground Shaker's Avatar
I take it these tires will not work on a 99 then. This is my first dually and I'm also having trouble finding a size/spacer that will work well.
Old 08-22-2007, 04:02 PM
stuckey200224's Avatar
255's will rub on the rear without at least a 1in spacer you can get a 1 or 2 in spacer at national tire and wheel i dont think you can see them on there web site but if you call them they keep them in stock (www.ntwonline.com)
Old 08-22-2007, 04:09 PM
Registered
blackdiesel's Avatar
255's didn't rub on my truck or dads. They will rub with the 2000 and older rims (less offset)
Old 08-22-2007, 04:53 PM
Muddin_dude06's Avatar
A good friend of mine just put 295's on her '04.5 with a 1.5" spacer on each side on the rear. I would think 2" spacers would be fine on our 2nd Gens with 285-295's...
Old 08-22-2007, 05:08 PM
255x85x16 bfg mt rubbed on my 01 what tires sre you running?
Old 08-22-2007, 05:26 PM
kxhonda's Avatar
On my 99 my 255/85/16 BFG Mt's did not rub at all when unloaded but with a trailer they would just touch.
Old 08-23-2007, 03:45 PM
I have 235 85 on the rear and 265 75 on the front. If i run a 255 85 on the rear am i gonna be able to run wider on the front like i am now or am i gonna have to run a 255 85 on the front also.
Old 08-23-2007, 04:29 PM
Registered
You will have to check, but I think a 285 is the same height as a 255
Old 08-24-2007, 02:24 AM
Ph4tty's Avatar
Depends on the ratio. 265/75 and 235/85 are about the same height, but the 255's are about 1.5 inches taller
Old 08-24-2007, 05:05 AM
the_fox_man4's Avatar
245 75 r16 on my beast here, loaded with trailer they peck on the turns.empty they have about 1/4 -3/8 clearance . but before I trailer heavy I armoral between then or baby power, and it takes the friction away from the rubing of the TIRES . learned that trick from a Buddy that was a trucker for the army. said that did it when they were over loading the trucks. I have some 5/16 spacer to put I when I get around to it..
Old 08-24-2007, 11:33 AM
jimk403's Avatar
255s are almost exactly the same height as 285s. On a 2000, they don't rub, even when I had 4400lb of dg in the back(not in this pic).
Old 08-24-2007, 02:30 PM
HDBeauty's Avatar
I just put 285/75 BF Goodrich AT KO on my truck with a 2" spacer. I will post pics when I can.
Shayne
Quick Reply: How big and wide can i go
