BHAF lifetime
Old 02-19-2007, 11:56 AM
Iron City's Avatar
BHAF lifetime
I'm thinking about replacing my BHAF now. I was curious, under highway driving conditions, how many miles or months should a BHAF be replaced? I do not use a heat shield or Outerwears cover. Thanks.
Old 02-19-2007, 12:29 PM
torquefan's Avatar
It could easily last 20-30 thousand miles, I would think. Shining a light through it will give you an idea of how much fine dirt is plugging up the pores. Did you install your filter minder onto the BHAF when you installed it?
Old 02-20-2007, 01:31 PM
Iron City's Avatar
thanks torquefan, I did not install the filter minder, I wasn't sure how to incorporate it.
Old 02-20-2007, 02:53 PM
Need95-00CTD's Avatar
drill a hole in the stock piping or the bottom of the filter and stick in the filter minder....that simple, just make sure you clean the shavings and seal it properly.
I would think an easy 30K miles...the thing is huge, idk what the actual surface area is, but its easily 200% bigger than a stock filter...
Old 02-20-2007, 07:58 PM
pete97's Avatar
IronCity, where do you live in Pittsburgh. I live north of the burgh.
Old 02-20-2007, 08:13 PM
Registered
blackdiesel's Avatar
nope, highway conditions the life span is 50~60k
manjerovic
08-30-2006 04:18 PM
HOHN
08-01-2006 08:39 PM
bdaniel
06-04-2006 08:26 AM
jeepsuck
05-06-2006 09:52 PM
0akman
06-28-2004 11:23 AM
Quick Reply: BHAF lifetime
