BHAF Install Help
Old 02-23-2008, 08:45 PM
12VBLacKCLouD's Avatar
BHAF Install Help
Here are some pics of it installed in my truck. Can I get away with it being 3 inches away from my exhaust turbo? Anyone else running it like this or is there a better way?
Old 02-23-2008, 09:09 PM
Wild4kst8's Avatar
heat guard?
I couldn't tell from the pics... but do you have a heat guard/shield? or is that what you're asking about?
I would definitely get a heat shield on there... there's pics on here showing what happens without... i would hate to mess up a perfectly good air filter by not adding a shield... get the template, get some sheet metal & shears from hardware store, and make a shield... i also used some high temp black paint & painted mine
Old 02-23-2008, 09:15 PM
That was my next question if it was gonna meltdown on me, ill get a heat shield in there with some high temp flat black.
Old 02-23-2008, 09:18 PM
HOHN's Avatar
I think it will be just fine, but it might get soft on a hot day if you're towing heavy.
If you're towing really hard in hot weather, the fan clutch will be almost totally locked up, and there's a LOT of airflow under the hood-- I don't think the BHAF is in any real danger.
I ran mine with no heatshield for a year with no problems at all.
jmo
Old 02-23-2008, 09:23 PM
Ill take the truck out tomarrow and see how toasty it gets, ill let ya know how it goes..
Old 02-23-2008, 10:39 PM
Picture of BHAF and a dirty Holset HX35 from 170k on stock filters. There are pits on the leading edges of the compressor wheel and a nice layer of dust inside. Anything to be worried about?
Old 02-23-2008, 10:57 PM
b4wheeler's Avatar
I ran mine for at least a year without a heat shield..... It never got hot or had any problems... Of course it was not getting pure cold air like the stock intake was, so there may have been a performance deficit. Now I have the heat shield that is listed here on DTR and it seems to be fine.
Old 02-24-2008, 06:33 AM
JonnyThrottle's Avatar
I had it with and without the heat shield. Honestly on the performance side, there wasn't much if any of a difference. I never really thought about it that much though. I was more worried about sucking all the hot air in the intake, not it melting. I too built my heat shield off the template on this site, made it really easy
Old 02-24-2008, 12:50 PM
I searched last night for the template but couldn't find it, i guess ill wing it. Found the template in FAQ, can't open it... oh well
Old 02-24-2008, 01:44 PM
rebal's Avatar
heres mine with the AFE heat sheald
Old 02-24-2008, 02:08 PM
smokin95's Avatar
This is my heat shield. Made it out of aluminum. looks real good. sorry its not a better pic.
Old 02-26-2008, 01:32 AM
I need a fuel plate now that I got a little more air coming in. Its an improvement in flow and filtration over the stock filter, heat shield or not..
Old 02-26-2008, 06:11 AM
91rangerturbo's Avatar
Make up a heat shield for it. It's not going to hurt it.
Old 02-26-2008, 10:34 AM
Lenn's Avatar
https://www.dieseltruckresource.com/...=faq&faqnr=142
Here is the link for the heat shield template. It was very easy to make.
Old 02-27-2008, 11:35 PM
smokin95's Avatar
i never ran without it and figured it would suck in alot more hot air with out it
Rickcher
09-02-2009 05:08 PM
Ace
10-31-2007 06:46 PM
Mechanos
25
10-21-2004 02:50 PM
WJB
04-15-2004 01:49 PM
phox_mulder
19
12-24-2003 02:22 AM
Quick Reply: BHAF Install Help
