BHAF and cold weather
Old 04-05-2004, 11:45 PM
Shaders 24v's Avatar
HEY FOLKS!! Well it is April 6th and we got 20 degree windchills here in the Delaware Valley. Wife and I went to birthing classes tonight and we took the truck. BOY I will tell yah,she was singing tonight (the truck ). I could actually hear my turbo spinning at the redlights. This real faint whistle. As I was traveling about 55mph ,the engine was really humming. Like never before. Is this normal with the BHAF and colder temperatures?? OHH by the way, the engine did warm up to its fullest and it still made this "drone" if that is what you want to call it. Actually it sounded like it was in D 2.
Is it a S O P with BHAF's??
Old 04-06-2004, 01:17 AM
BigBlue's Avatar
You won't notice any power increase from the BHAF. Mine was loud all the time and I loved it. Cold or hot. My truck always drone's, but I guess when you have 4" straight pipe dumped at the rear axle it will do that.
Old 04-06-2004, 07:55 AM
Commatoze's Avatar
Re: BHAF and cold weather
Originally posted by Shaders 24v
...........Is it a S O P with BHAF's??
I think so, Tom. After I installed mine, I noticed a drone at interstate speeds. When you let off the throttle, the drone goes away. I wanted to make sure it wasn't drivetrain noise, so I replaced the stock airbox and the drone, while still there, was greatly muffled. It was always there, I just never noticed it. I reinstalled the BHAF again last night and this morning the drone was back again; it's something you have to live with I guess. I can also hear air being drawn into the filter too, but this isn't an annoyance. The big test is whether dealing with the drone for 4 hours on the interstate will take its toll on me. If it does, the stock box may have to go back on. -Dad-
Old 04-06-2004, 08:11 AM
RustyJC's Avatar
I installed a Turbo Air Guide about 6 weeks ago. It cut probably 95% of the noise associated with the BHAF. That wasn't the primary reason I bought it, but the quiet will be nice out on the Interstate when towing 10-12 hours at a stretch.
Rusty
Old 04-06-2004, 08:15 AM
Commatoze's Avatar
Originally posted by RustyJC
I installed a Turbo Air Guide about 6 weeks ago. ........
OK....I'll bite. What's a Turbo Air Guide?
Old 04-06-2004, 08:20 AM
RustyJC's Avatar
Basically, a honeycomb flow straightener. It takes the turbulent airflow coming out of the 180* bend in the inlet piping between the BHAF and turbo inlet and straightens the flow so that it is laminar in nature as it enters the turbo compressor impeller.
This design is commonly used in process piping, wind tunnels, aircraft jet engine intake inlets, etc. It's based on the decades-old standard practice on industrial engines such as our company manufactures that a minimum of 5 diameters of straight pipe is required at the turbocharger inlet. In other words, if the turbo inlet is 20" pipe, 100" (8'4") of straight pipe are required leading into the turbo to ensure non-turbulent airflow. When this isn't possible, the honeycomb flow straightener provides the same effect as long as the thickness of the honeycomb is more than 5 times greater than the effective diameter of each cell - the honeycomb flow straightener acts like a bundle of individual straight pipes whose length is 5 times or more greater than their diameter.
Rusty
Old 04-06-2004, 09:40 AM
infidel's Avatar
More info on TAG here-
http://www.dieselpowerproducts.com/tag
joel
01-22-2005 08:59 PM
wings
11-08-2004 05:32 PM
TurboTed
02-26-2004 08:54 PM
RoadDawg
12-05-2003 01:31 PM
Haulin_in_Dixie
01-24-2003 10:41 AM
Quick Reply: BHAF and cold weather
