Best ways to improve mpg???
Old 11-04-2003, 12:35 PM
GreyBoy's Avatar
Im curious as to what are the best ways to improve fuel milage on a 12v. Im only get 7.5-9 mpg city and that REALLY SUCKS!!!
i know afjusting the timing to 16* is good. Any body know anywhere in Colorado I can havce this done and how much would it cost???
How much would, lets say, 300 or 370s improve it???
How bout a #10 plate??? Will it make it worse???
Old 11-04-2003, 02:55 PM
RCW
RCW's Avatar
Re:Best ways to improve mpg???
The best way to correct your mileage right now is to replace the OEM AFC spring with the medium spring from an AFC kit, then move the AFC housing full forward on its screw slots. Cranking the star wheel on a stock AFC spring really cuts fuel mileage in town driving. You need the longer and softer spring from the aftermarket kit to restore your mileage so the governor arm does not slam so far forward at low boost levels.
The next biggest fuel mileage increase will be made by advancing your timing. It is not particularly hard to do and the instructions are found on www.dodgeram.org (just follow the diesel links). Judging from the changes you have done to your truck, you should have little problem doing it yourself if you cannot find someone to do it for you.
Most high performance injectors will decrease your mileage by increasing the fueling rate. There are some that use more and finer holes, and are internally polished that can increase mileage with proper timing. I would recommend you contact the suppliers and chat with them about the types of injectors they offer.
Old 11-04-2003, 04:45 PM
GreyBoy's Avatar
Thanks for the help. I moved the AFC housing forward and slide the cam plate back a lil. I'll see how that works. Now, are the AFC springs the same as a govener spring???
Also, Im assuming that adding a new plate will make mpg worse??? Because more fuel is being used???
Thanks,
Sam
Old 11-04-2003, 05:55 PM
Smokee's Avatar
The very best method is NOT to give anyone all that smoke to eat.
Right foot control adjustment.
Old 11-04-2003, 07:54 PM
WHIFF's Avatar
[quote author=RCW link=board=16;threadid=21987;start=0#msg205565 date=1067979345]
[/quote]
Cranking the star wheel which way? I adjusted mine after shaving my fuel plate so I wouldn't smoke so much, but I am still getting poor mileage. I have mpg envy when I read all of these posters who say they get over 20 mpg! I want that too :'( :'(
Old 11-04-2003, 07:59 PM
boughtadodge's Avatar
Greyboy I am in colorado also near salida I have the tools to set the timing and can assist you In doing it. PM me if you would like to do it.
Old 11-04-2003, 08:07 PM
Dr. Evil's Avatar
Greyboy,
Even with the 37" tires...I would think you should get better than that....have you adjusted your valve lash?, changed fuel filter and prefilter? ran some injector cleaner??
I would take cumminsgetsome up on his offer.....would be a good learning experience.
Good luck.
BTW, I checked out your pics....awesome truck....
PS: have you been to the www.dodgeram.org site???...lots of good info. check it out....
http://www.dodgeram.org/tech/dsl/maint/2nd_Gen-12v.htm
Old 11-04-2003, 10:03 PM
GreyBoy's Avatar
Thanks for the help guys!!!
cumminsgetsome, Im sending you a PM. How far is salida from parker/castle rock??? I cant quite place where it is.
Smokey, I try...
Dr. Evil, thanks. I have read quite a bit at DodgeRam.org, but its been a while. I will go look over that stuff again. What do you mean by Valve lash???
Thanks,
Sam
Old 11-04-2003, 10:14 PM
Dr. Evil's Avatar
I mean, have you adjusted your valves lately ?
Its supposed to be done every 24 00 miles (or once a year at least)
Have a look.....
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
Old 11-04-2003, 10:57 PM
GreyBoy's Avatar
Nope, I havent done it at all, unless the dealer does it when when I take in it...I doubt it. It doesnt look like too hard of a job. Have you done it yourself??? Is it very difficult??? How long does it take???
Thanks,
Sam
RollsCoal
09-11-2013 05:35 PM
ilovemy12valve
11-25-2008 08:14 PM
grecododge
36
02-25-2008 11:05 PM
hic316
21
09-18-2006 01:13 AM
rufusrufgut
30
02-14-2006 09:04 PM
Quick Reply: Best ways to improve mpg???
