Best Way To Change A Carrier Bearing?
I just bought my 1 peice yesterday. (bit pricey $$ but worth it I guess long term)
But I would like to fix my old 2 peice for reselling. Is the carrier a dealer only part? I can't find it online.
Does it just slide off the shaft once the middle ujoint is removed?
The stupid bearing seems to be OE only, expensive, and cheap to boot. A one piece drive shaft even at twice the price is probably a good option.
A one piece is is around $550.
Yes I saw your Tom Addis and CDA, hello neighbor. I just saw on another forum that Dodge replaced all his U joints under the 7/70 warranty. Not sure if I have that warranty but will check it out.
I ended up taking my 04s whole driveshaft into napa and they pressed that bad boy off. while they was at it, i had them replace all ujoints with the brute force greasables.
