Best place to buy Mach Injectors?
Old 05-28-2010, 04:15 PM
progrower's Avatar
I'm looking at upgrading to Mach 1 or 1.6 injectors. Wheres the best place to get them?
Old 05-28-2010, 04:42 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Give Lary a call. Toll Free: 877-375-1956
He runs this site's on-line store and see what kind of deal he can work.
Old 05-28-2010, 05:09 PM
DIESELWRKS's Avatar
Rip at sourceautomotive.biz is a dealer and will beat anyones price. also be aware if you buy on ebay because of a great price. even though it may be a new mach injector they may not warranty the injectors.
Old 05-28-2010, 05:36 PM
progrower's Avatar
Thanks Guys, I'll give them guys a call.
What do you guys think would be better Mach 1 or 1.6? I want a mild increase in power and hopefully a small increase in mileage if im easy on the pedal. I do plan to upgrade the trans in the future depending on how long it last.
Old 05-28-2010, 06:23 PM
DIESELWRKS's Avatar
90 hp. but I went to my mach 4's from 90hp nozzles and I gained mpg. they are really clean burning injectors, smooth and cooler EGT's
Old 05-31-2010, 07:03 PM
high bid's Avatar
Like stated if you're not towing and want to use the factory turbo...go w/the M4. However...I tow and just installed the 1.6, love them and see max egts of 1150*. Towing w/the M4 has been proven to be too difficult as the egts will be out of control. Just ideas.
Old 05-31-2010, 07:14 PM
scottsjeeprolet's Avatar
I have the M3's and love them. They do run a little hot with the HX35. I have a 35/40 waiting to go in soon. M4's and stock turbo will be way too hot and smokey. I'm pretty sure you have the little HY on your truck too.
I'd say the 1.6's would be fine for you.
Old 06-01-2010, 10:10 AM
Midnite's Avatar
How do you have your Adrenaline set when you tow? I can sail past 1300 degrees with ease with my Mach 1s and Comp on 4x5, and that's with a hybrid HX35/40.
Mike
Old 06-01-2010, 10:30 AM
With the AD it's easy to set it. Pl0 is off, Pl1 timing only, Pl2 timing & fueling & 3 and up is timing with wire tapped fueling.
I run the latest Comp tune on Pl5 most of the time and it can get toasty fast!
Old 06-01-2010, 10:51 AM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Currently we do not carry F1 injectors but I would like very much to change that. Sorry I can not help you....
Old 06-01-2010, 12:00 PM
8UPRACIN's Avatar
I pull all the time with my Mach 7s and my twins are awesome at keeping it cool. If you know that you are going to upgrade turbos later go with a bigger injector now and turn your box down or off. I can tow my 27' enclosed trailer over passes at any speed and egts are always under control, hard ever seen over 1100 degrees
Old 06-01-2010, 02:40 PM
progrower's Avatar
What kind of boost & egts can i expect with the M1.6? As far as i know i have stock injectors and with the Xzt+ on I can hit around 1100-1150 degrees and 32 psi. I do have the wastgate turnbuckled shut and i do know these boost numbers are plenty high for the HY35. Just tryin to figure out if the 1.6s will be to much fuel for my current setup.
Like was mentioned above I would leave the xzt+ off if i put in the 1.6s
Old 06-01-2010, 04:00 PM
Midnite's Avatar
I'd set it at about 30 psi personally. You'll probably find that you'll have to regulate EGT with your right foot, and maybe do some experimentation to find a configuration that you like.
Mike
Old 06-01-2010, 06:18 PM
rebal's Avatar
my 1.6s with a smarty on 9 will shoot past 1400* at 38 psi boost with an HX35 If I keep my foot buried
Old 06-02-2010, 08:35 AM
high bid's Avatar
Mike
I had the ADR PL02 towing the boat (about 5k)this past weekend, outside temp 90*. Max egt was about 1150*.
ScreaminEagle
04-08-2011 08:37 PM
5.9Excursion
11-21-2007 06:50 PM
fade94
10-10-2007 09:01 AM
RonA
09-04-2007 11:09 AM
sway825
12-08-2004 10:21 PM
Quick Reply: Best place to buy Mach Injectors?
