Best place to buy a blower motor
i like to use www.rockauto.com they will take care of ya there. if you want new or if you want used witch i wouldn't bother on a blower www.car-part.com . also if the blower only works on high setting it's the resister that needs replaceing also if the other settings only work part of the time it's the reister. now if the blow make a Whine like mine does it's the blower but i am not going to change it until it stops. pluss it's to cold out.
He said that he could hear it barely running, then he hit the housing and the motor started running full speed. So he figured he needed a motor. Don't know.
I would pull the resistor first and take a look, just two screws. I get my parts from.
http://www.trademotion.com/partlocat...?siteid=214436
So far the have been realy good and the cheapest I have found for factory parts.
I have the same problem on my 01. Only blows on high AND it whines the first 30 seconds it is on. Gonna change the resistor and the blower motor.
Here is a link I found for a service manual for 01's. Download it and open it. It gives pictures and instructions for both the resistor and the blower motor. The resister is in the "power center" (basically a fuse box?) in the engine compartment. Good luck.
http://www.neonix.org/nero/files/2001ramsrvcmanual.zip
Jim Lane
04-05-2020 06:03 AM
Valv
08-05-2009 11:35 AM
5.9Excursion
11-21-2007 06:50 PM
Sarge1124
15
03-24-2003 05:41 PM
tobyw
11-12-2002 10:15 PM
