Best option for +MPG?
Old 08-13-2008, 05:15 AM
bige41084's Avatar
Heres my question, would I see more of an increase in MPG if I got an intake on my truck, or if I put a programer on? Ive read diffrent posts and I have mixed feelings on what would be best. Before anyone says it, yes I know Im driving a truck and I know its not going to get "car MPG" but still, id like to see better then 15MPG highway! Anyway money is kinda tight so it would be one or the other.
THanks
Old 08-13-2008, 05:21 AM
annabelle's Avatar
Forget the intake, air up your tires and get a Smarty.
Old 08-13-2008, 07:53 AM
TMan's Avatar
I have experimented with a couple of different things so far.
1) Painless Striker One Module.----Increase in driveability---0.0% improvement in MPG.
2) LubeGaurd Bio Gaurd EOS. 1.2 MPG increase.
3) Magna Flow 5" full exhaust. (off road use only) Just installed but so far on three tanks of fuel it has gotten over 1.8 MPG better.
I usually get right at 15.6 MPG in in town driving. I hand calculate every tank.
The Lube Gaurd stuff I got for free, so I ran it for an oil change worth and mileage went up, when I changed my oil I didn't run it and my mileage went down. This oil change I am buying it.
The Magna Flow exhaust, I can tolerate the sound in Town but towing with a load, It's LOUD really loud. I am going to see if I can keep the 5" pipes and change to a Donaldson Muffler.
I have ordered a Smarty Jr, expect it any day now. After a month of running it I will post my unbiased honest notes. It will either work or not. I got no dyno numbers to prove, no swinging members that need to be bigger than others. Stay Tuned.
Old 08-13-2008, 12:07 PM
dale29's Avatar
I've been adding 2-stroke oil (3/4 oz per gallon) for 3 tanks, then the 2-stroke and power service (3/4 oz per gal) every 4th tank. It seems to be working well. Last week I pulled my little cargo trailer (5-6k) from Austin to Tallahassee and back and averaged 14+ I got 15.1 on the tank from Loxley AL to Iowa LA (hand calculated).
The very biggest thing you can do for MPGs is to drive between 65 and 70, keep the rpms below 2000, it makes a huge difference! 65 will give you almost 1 mpg better than 70. Of course that turns a 10 hour trip into an 11 hour trip, but you can't have everything....
You could try a Max mileage module, some guys swear by them, I didn't find that it made any difference, in fact I will sell you mine, it's in the classifieds for 100 bucks.
The "smarty" will run you between 500 and 700 but some guys swear by them, you'll want to get a set of guages installed before you go smarty so you can monitor your egt's, fuel pressure,& trans temp, you don't want to tear up your truck. Good Luck....
Old 08-13-2008, 12:15 PM
Billm2004's Avatar
my girlfriends dad claimed about a 2 MPG increase with the quad max milage.
my truck responded well with the intake, but i already had the BDTD at that time.
Old 08-13-2008, 01:21 PM
goose2w1's Avatar
I have tried the Edge Juice, Diablo Puck, Diablo Predator, and the Quad X2 all by themselves and in different stack combo's. The best I could ever get was around 1.5 MPG better. When I got the Smarty, I downlaoded the TNT on #7, RP2, TM2, TQ3 and Wastegatoff. This got me 22MPG on my last 3 hour trip to and from Albq. NM! I never got that before! Cruised at around 70-75 the whole way. This is hand calculated too! Overhead read mid 24's.
Old 08-13-2008, 03:37 PM
moorepower's Avatar
My A.R.E fiberglass flat cover picked up a good 1.5-2.0 mpg depending on speed, and 4.4 beta picked me up 1.5 with light foot. Going 75 I get 17 and going 60 I get 22-23. So the best answer is the one no one wants to here. Slow down. I am sure the 6 speed helps also.
Old 08-13-2008, 04:22 PM
cbrahs's Avatar
Ok Barack!!
just messin! LOL
Old 08-13-2008, 05:37 PM
annabelle's Avatar
LOL....but airing up to 80 PSI and not driving over 1800 RPM gained me 2 MPG. But watch it.....them is fighting words! LOL
Old 08-13-2008, 07:11 PM
davelinde's Avatar
FWIW the best economy I've gotten so far was at 80PSI so I left it there (even though I'm not towing now).
But... that's physics not an energy policy so I'm not goin' there.
Old 08-13-2008, 08:46 PM
iflych52's Avatar
Driving 65mph with my truck in sig and stock tires at 80psi I am getting a 20-21 hand calculated.
Old 08-13-2008, 09:24 PM
annabelle's Avatar
Dive 1800 RPM (about 65 MPH) tires at 80 PSI......getting 23.7 hand calculated.
Old 08-13-2008, 09:29 PM
RSOPNCO1's Avatar
I went from 17 MPG to 20 MPG all hand calculated. I was running the Quad X2 on the 65hp setting and slowed down just a touch. Under 2k rpms makes a BIG difference. Afterwards I changed to the milage tune. Have been getting a solid 20 for a few months now. With just the intake i got about about .5 mpg increase. i took a bout a month or so before the truck started to really respond positively on the mpg side after the X2 install. I went through the same thing you are going through only it didn't start at the 15mpg mark. For me it was a toss up for the X2 or the Smarty jr. I got the X2 here on the classifieds. really not sure why i waited so long. Good Luck to you.
Old 08-13-2008, 10:40 PM
cbrahs's Avatar
40 psi on 39.5x13.5x20 Super Swamper Iroks with 3.73 gears, smarty on 3 version 4.11 stock torque mgt.. 1700 RPM's = 78mph and get 18.1 mpg hand calculated. Not too bad for a big truck
Old 08-14-2008, 06:51 AM
mm73's Avatar
original version of the smarty on sw5, 60 psi in 35" tires and 6 inch lift doing 75 and 80 and hit 100 twice passing really slow people in the slow lane, and I got 19mpg. Not bad for a lifted truck. and whats funny is my dad has a dmax 1 ton with bullydog and an air intake and he can only get about 15 to 17.
Quick Reply: Best option for +MPG?
