Best Electronic Guage Setup
Old 06-14-2007, 09:31 PM
CReed's Avatar
I need some input on an electronic guage setup. Im not a huge fan of the oulook monitor due to its defueling even when defueling parameters are set at their max. I do like the BD X monitor but dont really like the old hatch mark type deal ive seen a few that some of the hatch mark deals dont light up so their are parts of numbers that dont light up. The commander has everything i want EGT, Boost, Trans. Temp., Rail Pressure etc. but i dont really like the look of it if that doesnt sound to wierd. I do like the Ts Performance set i think its called a MPD or something like that however it doesnt do trans. temp. as far as i can tell from what ive read or maybe it does anyone know but i like the look and lighting style it has. Not a huge fan of the recon either. I do kind of like the Edge Attitude not really messed alot with them though will they work without a juice box? Does anyone else have any ideas without having to go with analog style guages, I think ive covered all the guages i know off any suggestions are greatly appreciated.
Old 06-14-2007, 11:17 PM
rustyshakelford's Avatar
well my first choice is analong because for some reason i trust them a little more than the others, but since you want electronic, i would lean more towards a quadzilla product before anything else. i just ordered my new rp and fp gauge and its a quad so ill let you know how that works out for me if your curious. everything else is analong though
brett
Old 06-14-2007, 11:45 PM
CrashCade's Avatar
Check out Bully Dog's PMT... It is a pretty cool deal.
Old 06-14-2007, 11:56 PM
CReed's Avatar
It defuels 2 and i dont want to run a bullydog programer right now making more power with my current setup. Maybe in the future when we can get the kinks worked out in some stuff ill go back to it. But thanks for the reply.
Old 06-15-2007, 12:09 AM
qzilla's Avatar
Just FYI, the Attitude and the Commander use the same display and backlight made by the same manufacturer??The Commander just uses a larger size than the Attitude. Of course the plastic is different and you can't run the attitude without a Juice.
Old 06-15-2007, 12:24 AM
CReed's Avatar
Ya just realized that about the attitude, The commander is nice but just bulky i guess just not that appealing to me qzilla but i guess im leaning towards using it being that it has all the features that i want anything else out their that i missed?
Old 06-15-2007, 02:12 AM
Mule Man's Avatar
Works good for on the a pillar with handle. Very responsive.
http://www.dakotadigital.com/index.c...rod/prd367.htm
Old 06-15-2007, 08:32 AM
jrussell's Avatar
Yeah, it sounds like you might want to check into those. I use SPA dual digital gauges and couldn't be happier with them. Accuracy and response is outstanding.
Old 06-15-2007, 05:55 PM
CReed's Avatar
I have looked at those just not really investigated on them any the one that does egt/boost/temp. can the temp be used in any location(Tranny/Coolant, etc.)?
Old 06-15-2007, 06:13 PM
Mule Man's Avatar
Yes, tranny or coolant.
Old 06-15-2007, 09:11 PM
drewblood's Avatar
yes Im looking at intake air temp with my temp sender you can have a setting that flashes the display of lets say boost mines set to flash at 45psi boost only defueling is by your foot on accellerator same for egt and temp been great for a year not a single problem with it and I just put the sender under the hood one small bit of wiring through firewall gromit and a ignition wire
wildcard
16
05-03-2008 08:28 AM
ryanihf250
01-17-2008 02:58 PM
bigragu
01-24-2006 11:16 AM
Evildiesel
06-30-2005 04:27 PM
SilverDiesel
12-12-2003 03:41 PM
Quick Reply: Best Electronic Guage Setup
