Best Drop In Air Filter
Old 07-11-2007, 03:57 PM
JR GOUGH's Avatar
Which Is The Loudest And Best Filtration For A 2006.
Dry Filter That Is ?
Old 07-11-2007, 04:14 PM
STate's Avatar
cant really say which one is best. but i put a fram in once and it reduced my fuel mileage and made my restriction indicator show poor air flow. I immediatly pulled and chucked in the garbage!! I have used the mopar OEM filter a couple of times and have been happy, but have been using the Napa Gold air filter the last several changes and for the price its my fav.
Old 07-11-2007, 04:54 PM
truckjunkie's Avatar
I really like my Amsoil eaa189 filter (I think that's the part number). It's reusable, takes a low pressure air hose to clean, makes the turbo whistle a little louder, and doesn't pull the air restriction gauge down after the first 10 miles like the stock one did...
Old 07-11-2007, 05:39 PM
ABQFirefighter's Avatar
Ditto that........
Old 07-11-2007, 09:12 PM
rockcrawler304's Avatar
Amsoil Eaa19 here too. Had it for about 3000 miles now and have tried to pull the filter minder down but it has NOT moved yet. The stock filter would oull down on the first mash of the go pedal. I also drive in a dusty area and the tube out of the filter housing is spotless
Old 07-11-2007, 10:17 PM
VaultRam's Avatar
I have the amsoil and my minder is down everytime I hit the pedal hard. Other than that I like it....had for 20k now!
Old 07-12-2007, 07:08 AM
MikeyB's Avatar
Amsoil Ea here. With the stock filter the filter minder would pull down to 50% at WOT, Ea is 30-35% (when both are new). This is with a modified airbox.
MikeyB
Old 07-12-2007, 07:32 AM
mlmiller's Avatar
amsoil air filter and no silencer ring and airbox down tube obstruction removed love that turbo sound :
Old 07-12-2007, 01:23 PM
HotRodK's Avatar
Thumbs up
On my truck with the Amsoil filter and Modded airbox, I get no movement from the filter minder either. I dont have much else done to it but a BD tuner though.
Old 07-12-2007, 01:38 PM
belgianmagic's Avatar
Thumbs up
this thread LOOKS LIKE AN AMSOIL SALES PROMO...
I have the K&N drop in replacement filter...works awesome HOWEVER I will NOT clean and re-oil it myself...over oiling is a MAJOR problem so When its time to replace I WILL buy another K&N
I ALWAYS have my toenails in the fan (throttle mashed) and it NEVER starves for air...
the oem lasted 500 miles ,this has 22,000 on and still fine
Old 07-12-2007, 03:54 PM
That's why I went with the Amsoil. Even subconciously I think my mind thinks that if a little oil is good, then a little MORE oil is better . I went with the Amsoil so I don't have to think about it. I generally just take it out and blow it out with the (low pressure) compressor hose and put it back in at every oil change - takes like 5 minutes. Like stated above, the intake tube is clean - it even stood up to a white cheescloth test.
Old 07-12-2007, 04:25 PM
BPoulsen's Avatar
Another vote for the K&N - never had a problem and the tube to the engine is always clean - no dust!! The filter minder hasn't moved since the dealership put it in either...
Old 07-12-2007, 04:37 PM
Hippie816's Avatar
Better watch out. AFE has a dry drop in available. I have the full pro dry system and it works great. Veryvery loud. I don't think it could be any louder with no filter. Give those 6.ohs a run for their money, sound wise thst is.
Old 07-12-2007, 06:03 PM
TBNorge's Avatar
I use Fleetguard. Doesn't pull down the minder and I replace it every 10,000 miles. P.S. the minder is junk, use performance as an indicator. Loss of performance, put on new filter.
Old 07-12-2007, 09:36 PM
OR Mega Cab's Avatar
I am happy with my Amsoil EaA189. While I had the filter outl I also drilled about 20-30 3/4" holes in the bottom of the stock air box. The stock filter was pulling the filter minder down to about 40%. It has not moved at all since installing the Amsoil filter and drilling a bunch of holes in the bottom of the air box.
jbham
01-26-2009 09:20 PM
hyunsinsone
05-28-2007 11:17 AM
ValkSmile
01-04-2007 08:32 PM
Thundercloud
11-05-2006 10:31 PM
Badd Dogg Guy19
03-22-2006 10:05 AM
Quick Reply: Best Drop In Air Filter
