bent end link
Old 07-15-2007, 11:08 PM
panama's Avatar
bent end link
I just noticed today while cleaning my truck that I have an end link on my driver's side that is bent quite badly. The passenger one is tip top and just wondered what could have made that one go, and what could happen with it being bent. I just found out that you should put longer ones on, or the drop block but a little to late.
Old 07-15-2007, 11:46 PM
firemansdiesel's Avatar
Did you take it off road and do any articulation? Stockers are cheap. Go to Lorenz or Carli and buy one of thiers. Never have to worry. They are both under $200 for a pair.
Old 07-16-2007, 08:29 AM
jrussell's Avatar
It most likely happened during the leveling kit install. A lot of shops don't bother to unbolt the sway bar links and the weight of the axle pulling on it will bend them every time.
Old 07-16-2007, 09:05 AM
RamWheelsBy4's Avatar
As stated above with the leveling kit and no stabilizer drop blocks with they can bend pretty easy with articulation. Bigger the tires, the easier.
I bent both of mine early on with leveling kit and 315s and replaced with new stock ones. When I removed the lift kit and went to 285s, the driver side was bent. The guy at the 4 wheel shop just took a large pry bar and straightened it out. Been straight since for the last 20k miles.
powermad
18
05-27-2009 07:33 AM
95black2615
0
06-14-2006 07:43 PM
Inferno Ram
06-11-2006 10:53 AM
600 Megawatts
27
09-29-2005 05:49 PM
ob1kobi
02-17-2005 10:14 PM
Quick Reply: bent end link
