Belt Tensioner Question
Old Jan 3, 2006 | 12:32 AM
BearKiller's Avatar
I don't quite know how to word this question.
I have a 1st Gen. 89 model engine that is going in a Ford ton truck.
I have custom-built an alternator bracket that mounts the Ford alternator in relatively the same position as the Dodge alternator.
The air-conditioner compressor has been removed; so, basically, the belt will be routed the same as it would be on a Dodge without air.
My question is, how much travel is taken out of the tensioner when the belt is mounted?? i.e. how tight should the tensioner be with the belt on the engine?? At which extreme of it's travel should it be with the proper length belt??
I need to know this so I can measure for proper belt length, in case it works out to be different than O.E.M. length for a non-a/c Dodge.
Old Jan 3, 2006 | 01:50 PM
97catintenn's Avatar
Generally the tension is in the middle position with the belt on. You have to be able to move the tensioner in the tighter direction to remove the belt, so make sure you have some play there.
Old Jan 3, 2006 | 03:31 PM
John Faughn's Avatar
Every tensoiner I've work on [ trucks & cars ] has had indicaters on the tensoiner for wear limits [ streching ] about 1/2-1" between new & used , if you look closely you'll see a single mark on a surface that pivots and 2 marks that the single is inbetween when the belt is mounted.
Old Jan 3, 2006 | 06:33 PM
BearKiller's Avatar
Thanks for the info.
I will look for the wear marks as this is the first time I have known they existed.
peobryant
Oct 3, 2012 07:16 PM
bigragu
Apr 8, 2007 02:44 AM
apwatson50
Mar 3, 2006 06:26 PM
Commatoze
Oct 24, 2002 09:32 AM
