PDA
View Full Version : Bead locks????
dieselcarpenter
10-28-2007, 03:54 PM
I have never run or messed with bead locks,but I do know how they work. My question is, the ones I see on TV only seem to lock the outer bead. I saw a set one time that had an inner bushing to lock the inner bead but only once. What good is only locking the outer bead? Unless I am stupid and never noticed them locking both??????????:confused:
Honkylips
10-29-2007, 01:21 AM
While inner beads will unseat at times, it's pretty unusual. It's usually the outer bead that unseats.
BRUISER
10-29-2007, 07:18 AM
exactly..
Plus you can get "hummer" beadlock which do lock both outer and inner beads.. the rims are a 2 piece design with a magnesium or plastic inner piece that holds the beads together.
there are also a few companies that do make outer and inner bolt on beadlocks.. but you have to get a bigger rim like a 17" to clear brake calipers.
LanceD
11-03-2007, 05:02 AM
I have double beadlocks from www.stazworks.com. I love them. although I do wish I would have got 17s
http://memimage.cardomain.net/member_images/6/web/414000-414999/414017_389_full.jpg
getting the ring into the tire is fun
http://memimage.cardomain.net/member_images/6/web/414000-414999/414017_381_full.jpg
JKM
11-03-2007, 02:17 PM
Lance , what are a set of rims like that worth?
LanceD
11-03-2007, 06:43 PM
they have a price list on their site somewhere, but you can get them in pretty much any size you want. and if you want a custom pattern, say a big Cummins C in the rim all the way around, he can make it.
JKM
11-09-2007, 04:59 PM
sounds pricey... I don't need beaklocks, those rims just look awesome.
JKM
11-09-2007, 05:03 PM
I just looked , they are over 300 bucks a pop for the size i want, i can get non bead lock alloys in that size for a little over 160 a piece...
dieselcarpenter
12-04-2007, 03:46 AM
Are there any double locks that are DOT approved ??
Honkylips
12-04-2007, 09:25 AM
http://www.high-impact.net/wheels/dot_approved_beadlocks.htm
LanceD
01-02-2008, 12:43 PM
the wheels from the H1 hummers are.
also the ones I got have DOT numbers on them.
crucescrawler
01-02-2008, 03:17 PM
Staun makes an internal beadlock system. I have weld on beadlocks on my jeep, but my dads jeep has the staun setup. pretty pricey, but if you trash a wheel, you can pull them out and reuse them on another wheel. They are also DOT approved. Oh, and they on 16.5 wheels, and we both run about 5-6 lbs in the rocks... Something interesting to look into for sure...
LanceD
01-03-2008, 04:24 AM
yeah I forgot about those
tristan21
02-03-2008, 07:54 PM
Dont forget that they are REAL heavy. At least I think I remember reading that in four wheeler.
