BD Tow twins wastegate adjustment
I was told I should go ahead and shorten the wastegate all of the way. What would this accomplish? I have it set to 48 or 50psi. Any side affects from doing this or will it get me some more power.
1 Post
Shortening the rod will raise boost. Once you get above 60lbs, drive pressure starts to climb quickly. I wouldn't recommend shortening the rod all the way. Shorten it in small increments (two full turns at a time) until you reach 60 lbs and stop there.
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
MoparRiggan
10-13-2005 11:54 AM
