BD Adjustable track bar kit
Old 04-17-2010, 01:37 PM
CTD2001's Avatar
Has anyone installed this kit on their truck? If so was it a straight forward install? How long did it take to install? Does anyone know if this track bar kit will work with a Mag Hytec Diff cover? I have been searching around and the 2nd gen design style adjustable track bars dont seem to work with the Mag Hytec covers. I just want to make sure that this kit will work with the cover before i order one. Has there been a improvement in handling after the kit has been installed? Thanks for your time
Old 04-18-2010, 03:09 PM
CTD2001's Avatar
No one has installed one of these kits yet? Just looking for some feed back on it before i order one. Thanks
Old 04-19-2010, 02:14 PM
bhuffstutter's Avatar
I put one on my truck but it is a 3rd gen so don't know if it will work with the mag cover. It is a strait forward install, pretty easy to center the axel. when I installed mine I also put on new after market control arms and truck handles great now. I went with bd because the adjuster is easy access to make adjustments vs others I've seen.. I would recommend it.....
Old 04-19-2010, 04:37 PM
CTD2001's Avatar
Thanks for your input. I emailed BD directly but have not heard back from them yet.
Old 04-20-2010, 10:37 AM
Got mine from exteme diesel I think source atomotive has them too. Although it was on back order so I had to wait a little longer.
Old 07-08-2010, 06:33 PM
cjdakota's Avatar
I just put one on my truck and it was a little bit of a pain but not bad and when you get to the end you can see how much more solid this system ha got to be.Nice design and nice results. I deterred from the install directions slightly by tightening the bracket in place before the last two drill holes were marked and ran pilot marks then removed bracket and proceeded to drill those. two people are a must
77machomopar
20
12-11-2009 10:37 AM
CTD2001
08-22-2009 10:03 PM
BigBlue
05-12-2005 02:18 PM
Dodge Demon
01-19-2005 05:31 PM
RussellT
01-14-2005 09:03 PM
Quick Reply: BD Adjustable track bar kit
