Battery drain - Parked 5 weeks
Old 01-11-2007, 12:44 PM
TJT
TJT's Avatar
I will be parking my '99 truck for 5 weeks. I believe I read somewhere that there is a slow battery drain that will cause me problems if the truck is not run for 20 days or so. What should I do to my truck so that when I return, I will have no battery issues & all memories are in tact? I might be able to put a trickle charger on a timer & run it a few hours each day??? What have you done that will work for me?
Thanks,
TJT
Old 01-11-2007, 05:59 PM
old 300's Avatar
Want about one of those solar panels the you can hook up to your power point. I think they are about 5 watts or something, just lay it on the dash and plug it in and it should keep the batterys up. Just a thought, is the truck going to be outside or in. If inside just pick up a battery tender, we have a couple of those and they work great.
Old 01-11-2007, 06:19 PM
infidel's Avatar
Just disconnect the batteries, all you will lose is the clock and radio station settings.
Old 01-11-2007, 06:40 PM
Geico266's Avatar
You can plug in a Battery Minder 24/7/365, and it conditions (desuficates) your batteries.
Old 01-11-2007, 11:45 PM
TJT
TJT's Avatar
These are all easy solutions. I have access to a battery tender. If I can figure out how to leave it hooked up for 5 weeks without it getting stolen... , that will probably be my choice.
Thanks to all...
TJT
Old 01-12-2007, 01:45 PM
the_fox_man4's Avatar
mount the battery tender under the hood and run the cord under the hood also and tie the cord in a knot under the hood so some on can't just unplug and run off with the cord, and not plug it back in. I have left battery tenders on ou years. no damage done, and that was with checking the level of water 1 time, probaly shold look and the water level more but other than that alls well
Old 01-12-2007, 03:09 PM
dssimecek's Avatar
Don't think you have much to worry about. Our truck sat for about 3 month. Nothing hooked up to it, Just parked it. Came back and it fired right up, not the best thing to do, sometimes notmuch choice.
Old 01-12-2007, 10:52 PM
TJT
TJT's Avatar
dssimecek, That is what I was thinking. Maybe not much to worry about. However, I thought I read somewhere... maybe in the service book that something died after 20 days I have a hard time believing the radio, clock, & other computer functions would suck the batteries dry in 5 weeks. Even so, I'll probably do as fox man4 did. Tie it all up under the hood.
Thanks to all....
TJT
Old 01-13-2007, 09:03 AM
TIMMY22's Avatar
http://www.westmarine.com/webapp/wcs...allpartial/0/0
this is what we use on boats. also, i would think it would be a great theft preventative.
TxDiesel007
03-04-2007 02:19 PM
taken5875
06-08-2006 10:35 AM
Gronk
04-09-2006 06:20 PM
CRIVERHD12
02-23-2005 01:24 AM
Quick Reply: Battery drain - Parked 5 weeks
