Batteries
Old 10-18-2011, 08:39 PM
whiteeye42's Avatar
Batteries
Well it is getting close to time to replace the batteries in my 2008 truck i got the truck in nov of 07 so next month it will 4 years old and still has the factory batteries in it what is a good replacment for the factory batteries? what is everybody on here using?
thanks in advance
Old 10-18-2011, 09:52 PM
.boB's Avatar
I have an '07 with 65K miles on it. Factory batteries are still working fine. Winter is coming, so I'll be watching for changes.
Every few years, Consumer reports does a battery test. Interstate, Diehard, and Duralast are usually the top three for cold climates. I'v been using Duralast in most of my vehicles with good results.
When the batteries in my Ram die, I'll stop by Autozone and get two new ones.
Old 10-19-2011, 01:48 AM
ktpauley's Avatar
There are only a handful of battery manufacturers. I went to Deka/East Penn Manufacturer's plant and picked up 2 factory seconds. I think Deka makes the Duralast brand.
Old 10-19-2011, 01:59 AM
Hvytrkmech's Avatar
My 2006 factory installed batteries are still going perfectly strong.
Old 10-19-2011, 04:00 AM
Dustybowls's Avatar
I just bought 2 of the new Duralst Platinum batteries for my 07. They are AGM Batteries and Hoping they last.
I paid $160 each.
Old 10-19-2011, 08:28 AM
FarmerJim's Avatar
Unless you are having problems I would not be to quick to replace the batterys. I just replaced mine at 110K and they were still going strong but thought it was time, both still have the little green liglht working so I turned in 2 other old batterys and will use the take outs around the farm untill they give up.
Old 10-19-2011, 09:05 AM
whiteeye42's Avatar
kk thanks i guess i well wait until they start to show signs of going bad i was just going by most battery manufactures suggestions as to replace at or close to the 5 year mark. I just did not want to get caught this winter out and about someplace where there was on store to get a new if they went bad.what are some of the signs of a battery going bad other than the truck won't start.
rebal's Avatar
our 03 still has the factory batteries in it 220k and going.
Old 10-19-2011, 09:21 AM
.boB's Avatar
Time to replace can be a tough question. If mine dies, I just call AAA and they'll (eventually) send some one out to jump start the truck. Then I'll replace them.
But if you spend a lot of time in the back country, a dead battery is a serious problem. Replacing them before they fail is not a bad idea.
In Dodge trucks, the symptoms of a battery failure can be a little bizarre. The dash gauges and warning chimes start doing wierd things while running - especially at idle. That's often the first sign of battery failure - before it fails to start or has a slow start.
Old 10-19-2011, 09:41 AM
AH64ID's Avatar
I went with Sears Platinum P-2's, which are made by Odyssey.
Old 10-19-2011, 10:26 AM
infidel's Avatar
I hate dealing with corrosion and will never buy another conventional lead acid battery.
Absorbed glass mat (AGM) or dry cell is the only way to go.
My last pair of AGM Optima batteries went for nine years.
Well worth the extra cost.
Old 10-19-2011, 11:46 AM
fzr400's Avatar
my factory mopars in my 02 are still going strong. bulid date is 11/01 so 10yrs old. im blowwwwwn away
Old 10-19-2011, 12:41 PM
Dustybowls's Avatar
those are the batteries I really wanted but couldn't justify the $50 each price difference. I remember reading you got a awesome deal on yours due to a military discount...
My batteries were to the point they couldn't start my truck. Thats why I replaced them when i did.
Old 10-19-2011, 12:42 PM
AH64ID's Avatar
Yeah I was able to get them for $160/ea. The same price my dad paid for Optima's, but his Optima's have been nothing but trouble.
Old 10-19-2011, 12:48 PM
Dustybowls's Avatar
Yeah I would have jumped on those for that price.
Optima's sure aren't what thy used to be...
Quick Reply: Batteries
