Batteries going down and truck wont start
Old 10-30-2011, 08:17 AM
atthepark's Avatar
Put in two new batteries and truck sat for a week, went to crank truck and it wouldnt start. Turned slow and then wouldnt crank at all. Truck started fine the day I put the new batteries in. I am thinking that it is either the battery cables or the starter that has gone bad.
Any help would be greatly appreciated.
Thanks.
Old 10-30-2011, 10:40 AM
whiskers's Avatar
Check the battery voltages. Sounds more like something has drawn them down.
Old 10-30-2011, 03:04 PM
atthepark's Avatar
Battery voltage is a little above 12V.
Old 10-30-2011, 06:04 PM
whiskers's Avatar
Batteries should be 12.75 and need to be unhooked from each other for a true reading. If good, start with cable cleaning and retighten then on to starter.
Old 10-31-2011, 01:07 PM
joem's Avatar
sounds like a draw for sure, check areas that are effected by road grime, I found my draw being the trailer charge line in the RV connecter on the bumper- it was all rusted up by the ice melt stuff the poor on the roads
http://www.mhd.state.ma.us/default.a...ment&sid=about
Old 10-31-2011, 03:17 PM
CarlJensen's Avatar
Only true way to test a battery is with a load test. Meter won't tell you much. Autozone ,or the like, should be able to load test.
ThatGuy34
05-06-2014 12:37 PM
2006Mega
10-08-2010 06:33 PM
84mphcdt
01-17-2008 12:29 AM
Kman9090
08-07-2007 10:35 AM
qcstunter
01-09-2007 04:10 PM
Quick Reply: Batteries going down and truck wont start
