Basic 12v ??s go easy boys
Old 12-02-2005, 10:56 PM
ratsun's Avatar
Since Im a 24v guy (not for long) what the heck is a delivery valve and where is it, in the pump? I hear of 181-191ect what do those #s mean CCs? Also were the 98 5speeds 215 or 235hp?
Old 12-02-2005, 10:58 PM
Cummins Freak's Avatar
they were 215 pumps oh yeah and sweet trucks
Old 12-03-2005, 03:53 AM
halerazor's Avatar
http://www.piersdiesel.com/TechDV12V.htm
dv's are inside the injector pump very easy to change in about a half an hour. if you look at the pump you see 6 metal fuel lines coming out of it going to the injectors. remove the lines and then you need a special socket to remove the barrels and the dv's just sit right underneath there. 181's come stock in the 180(96-97 autos) and 215 pumps(96-98 manuals)), 191's are an upgrade, but if you want some real power get a set of laser cut dv's. dv's limit the amount of fuel sent to the injectors
Old 12-03-2005, 06:37 AM
Dangousity's Avatar
1996-1998 12 Valve General Engine Specifications
Engine: 5.9-Liter, OHV, Diesel Six-Cylinder
Type & Description: Six cylinder, in line, liquid cooled, turbocharged, intercooled
Displacement: 359 cu. in. (5.9 L)
Bore x Stroke: 4.02 x 4.72 (102.1 x 119.9)
Valve System: OHV, 12 valves, solid sliding tappet lifter/followers
Power (SAE net)
215 bhp @ 2600 rpm - 49 state manual
180 bhp @ 2500 rpm - all auto. trans
180 bhp @ 2500 rpm - CA man. trans
Torque (SAE net)
440 lb-ft @ 1600 rpm - 49 state manual
420 lb-ft @ 1500 rpm - all auto. trans
420 lb-ft @ 1500 rpm - CA man. trans
Compression Ratio: 17.5:1
BHP/Liter: 29.7 - man. trans.; 27.1 - auto. trans.
Max. Engine Speed (Governed Speed*) : 2700 rpm
Max. No Load High Idle Engine Speed: 3000 RPM
Emission Controls: All: Oxidation catalyst, CA: EGR
Old 12-03-2005, 08:24 AM
infidel's Avatar
Old 12-03-2005, 11:33 AM
ratsun's Avatar
Exellent!!!! Thanks guys now I understand
Old 12-04-2005, 11:47 AM
Dr. Evil's Avatar
Ratsun...if poke around on the www.dodgeram.org site - theres tons of good 12V info.
mr.mindless
16
09-13-2009 12:02 AM
skynyrd
03-09-2007 07:06 PM
robsredford
11-22-2006 12:39 AM
2500
30
10-15-2006 06:25 PM
whiteknight
12-31-2002 01:30 PM
Quick Reply: Basic 12v ??s go easy boys
