Bad Flutter, surge after CP3 Mod
Old 06-13-2007, 10:03 PM
Jays98dodge's Avatar
After CP3 Mod, my truck has a bad surge. Quick surge not like turbo surge. I used a scan tool to check rail pressure, rail pressure jumps up and down from 21000 to 18000. This only happens at a little more then half throttle. Wide open runs make you crap your pants. Any ideas?
Old 06-13-2007, 10:11 PM
t-boe's Avatar
Make sure your FCA is completely deburred. If it isn't, it will surge.
Old 06-13-2007, 10:48 PM
I sanded all edges with 1500. Works great until mide to hard throttle?
Old 06-13-2007, 10:58 PM
DTR's 'Go to Guy'
vzdude's Avatar
Try resetting the APPS. That has fixed more than a couple with similar problems.
Old 06-13-2007, 11:04 PM
tbarbee1's Avatar
Ok i'm a dork whats the APPS?
Old 06-13-2007, 11:15 PM
CrashCade's Avatar
This thread has the steps to do it...
https://www.dieseltruckresource.com/...resetting+apps
Old 06-14-2007, 05:12 AM
rich2500's Avatar
did you check the bore that the valve goes in for any burrs,when reassembling did the valve slide in and travel the full length very smoothly.
Old 06-14-2007, 12:01 PM
When I finished the valve went back and forth with out a problem. Smooth as silk. I made sure to check that.
Old 06-14-2007, 07:06 PM
drewblood's Avatar
I had the same problem and it went away after I installed the edge ez I assume it is fooling rail preassure as it does the boost sensor
Old 06-15-2007, 11:14 AM
Is there any other way to fool the fuel rail pressure (smarty)?
Old 06-15-2007, 04:30 PM
bob4x4's Avatar
The new beta version smarty does play w a lil pressure.
Bob
SlowSixSpeed
11-22-2007 04:15 PM
megacabrule
33
05-10-2007 01:07 PM
Alec
07-10-2003 08:34 PM
Cummnzpowr
04-27-2003 08:50 AM
Quick Reply: Bad Flutter, surge after CP3 Mod
