back up lights
Old 05-08-2006, 12:59 PM
chadwick's Avatar
back up lights
I noticed that my back up lights werent working so i took the cover off and the bulbs seemed fine so i tested them with a test light and i have no power to the lights. I was wondering if i should first start with the switch on the trani that tell the truck it is in reverse. Also if anyone could tell me which plug it was that would help. Any advice is appriatated
Old 05-08-2006, 02:38 PM
fschiola's Avatar
Did you check fuses? In the cab as well as at the power distribution center under the hood.
Old 05-08-2006, 05:27 PM
chadwick's Avatar
yeah i did the one incab turned out to be fuse number 7 and i dident find a fuse for the back up lights under the hood
Old 05-08-2006, 05:49 PM
chadwick's Avatar
sorry about the confusion in my last post all the fuses were good
Old 05-08-2006, 06:33 PM
chadwick's Avatar
I traced the wire(Purple w/black stripe) all the way back just to make sure it dident change colors. power going in switch on trani and no power coming out thanks for help
Old 05-08-2006, 07:28 PM
fschiola's Avatar
Have you tried to jump the wires at the connector to see if the lights come on?
Old 05-08-2006, 11:51 PM
chadwick's Avatar
well what i did is just poked inside the back of the connecter one was hot and one was not. so then i took it off and jumped them and the light came on. the problem now is all the parts stores are having a hell of a time trying to find the part. so if anybody knows the part number that would be great
Old 05-12-2006, 09:42 PM
Jim Dynomite's Avatar
You may have to go in to the dealer with the VIN#. DC used a few different vendors for the reverse switch. I took mine out and brought it to the dealer and they said to get the VIN cuz they have no way of telling which one I have.
..................Jim
03CTDCO
03-06-2010 10:48 PM
getrdun
11-26-2008 11:46 AM
JoshPeters
04-03-2005 08:13 AM
CHarlan
08-06-2003 08:40 PM
Quick Reply: back up lights
