View Full Version : axle jam nut
archer39
03-22-2008, 04:32 PM
do they make a special socket to get the jam nut off? I tried an assortment of punches and chisels to get it lose but it is just to tight. I have a spindle socket for a D44 but it is to small. the notches line up but not wide enough. These are normal threads correct? not left handed??
anyone have any other suggestions or tips?
thanks
G1625S
03-22-2008, 04:34 PM
It's a 2-9/16'' nut and you need a thin-wall axle nut socket. Usually, you can get them loose with a hammer and punch. They are standard threads. There should be a little retainer than presses into the slot on the spindle--did you remove that?
archer39
03-22-2008, 04:48 PM
thats the rear right^^^? i am working on the front
G1625S
03-22-2008, 05:05 PM
Oops, my bad. I'm not familiar with the newer style front d-60:( my 2-9/16'' works up front on mine.
Trooperthorn
03-23-2008, 01:44 AM
I got my '92 d60 front apart with my old trusty broken and slightly bent skrewdriver. Make sure the tab is not bent up in any of the slots. They make a special socket. There was a thread on it a couple of weeks ago.
Trooperthorn
03-23-2008, 02:01 AM
I believe this is the part you are looking for.
http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=SER&PartNumber=3246&Description=Spindle+Lock+Nut+Socket
archer39
03-23-2008, 08:42 AM
will that work on the jamb nut too? i read the post about it and believe the person was asking for the axle nut it self.
the circled part is what i can't get off.
http://i166.photobucket.com/albums/u99/archer339911/InnardsAsRemoved.jpg
this is where it is when installed in the hub
http://i166.photobucket.com/albums/u99/archer339911/ManualHubHousing.jpg
the bugger is really on there. i bent a screw driver to get a better angle on it but i ended up busting it. don't know what else to do. i am going to try the other side and see if i have any better luck.
DanMan
03-23-2008, 09:04 AM
Yes, that is the tool you'll need. When you're done with it send it to me, I've got a rotor to replace. :D
Free89W350
03-23-2008, 10:03 AM
If you were a little closer I would let you use mine. I got mine from the local auto parts store, can't remember if it was Advanced or National. One of them should have that socket in stock to either buy or rent.
archer39
03-23-2008, 10:11 AM
well i got the other side done no problem, i will have to make another trip to the parts store to find the right tool [duhhh]
powerrammaster
03-23-2008, 11:43 AM
I wish they would put this info in the sticky. I wrestled for a week to get the right socket, umpteen trips at $4/ gal had me fried. The proper spindle nut socket is CTA tools#4165. The socket for a dana44 will NOT work, as the one pictured above will not either. The Tool is a round socket, double thickness where it fits over the nut with 4 pieces of square stock protrudig into it at 12 3 6 and 9 o'clock. The Lisle tool combo socket is real close but after $35 and modifying it, it did not work. That was part #27400---No good. I tried others and returned also. PITA. Socket description must clearly state it fits 4500# dodge front axle. The CTA model works perfect, was only $20. and is avail at Bumper to Bumper stores.
big stinky
03-23-2008, 12:07 PM
I dont know why, but my dana60 front had the 2 9/16 nuts on the front. Made me cranky cause I have dana 44 and 60 normal nut sockets. (the weird lookin things) Dontcha love trips to the part store for a tool after the trucks all ripped apart?
Bookshelf
03-23-2008, 12:10 PM
I've posted asking about this before and was told it was a KD 3246, which looks like the NAPA socket. I've also been told its an OTC 7158, which looks like what you're describing, fits around the nut and prongs come in from the side. I looked in my 1993 Dodge service manual and it says to use "wrench 7158", maybe they're referring to that, it didn't specify a brand so I don't know for sure. I haven't personally tried either of these sockets, but I'm going to order the OTC one this week. Both of these sockets are available from places online. I will post when I get the socket whether or not it works. Socket part #'s(once verified that they work) should be in the stickys, along w/ the size socket for the earlier D60 and the one for the rear D70.
Bookshelf
03-23-2008, 12:12 PM
What year is your front axle, and was just the outer nut that or both of them?
powerrammaster
03-23-2008, 12:16 PM
Try this, these are all I had to try to finally find that #4165 is the proper one even though it is not the one that says it fits a dodge. Good luck, put this in the sticky!!!!.
http://www.ctatools.com/catalogs/2007MasterCatalog/39-44BrakeWheel.PDF
Just cut and paste this in the search bar...If you can not click on it.
BearKiller
03-23-2008, 12:27 PM
If you have one side off to use as a sample, take a suitable piece of pipe and make a socket that will fit.
Once you get the business end to work, weld a bar across the other end, with a big nut welded to it's center for turning with a socket.
The son's 90-model has the 2-9/16 hex-nuts with the folding-tab lock-washers, a much superior system, in my opinion.:cool:
powerrammaster
03-23-2008, 12:31 PM
This socket fits 90-93 front Dana 60's with the Warn style lockouts. There are two nuts in there, in a jamb nut configuration, meaning they are almost identical outside and inside nuts with a washer that has a lock pin on it to keep them from turning when together. The lock washer in the middle has flats which you peen over to lock it to the innermost nut. These nuts require part #4165 CTA or maybe the OTC 7158(we'll see soon?)... sockets to remove. In most cases the nuts can be driven off with a punch of some sort, but mine were very tight together, no choice but the proper socket. The older 60's('89 and older) with the Selectro lockouts take the large rounded nut (2-9/16") I believe?? May have that mixed up as it has been a few years since workin on one of those.
powerrammaster
03-23-2008, 12:38 PM
I thought about making the socket-- easy enough to do with heavy wall pipe and square stock keyway type material. It would've taken longer to find the pipe at a metal shop, then fabricate, etc, and prolly cost more too. $20 is cheap, and it's heavy duty. Just wish I coulda got one off for a sample, I wouldn't be writing this. I am doing this for the good of this community based on my trial and tribulation.
Bearkiller- your son's truck must be a very early 90 with the Selectro's??
Bookshelf
03-23-2008, 01:16 PM
Thanks for the link, I'd never heard of CTA tools. That looks just like the OTC socket, we'll see if that fits also. The more brands the better!
big stinky
03-23-2008, 02:13 PM
My papers say 91, but the axles say 89 and i have the early grill...
archer39
03-23-2008, 04:06 PM
thanks a lot for the info, i too have made many trips to the parts store. Now that have the one side off i have something to sample it to. My grandfather says he has the right one so we will see tomorrow.
dzl_damon
04-08-2009, 07:07 PM
NAPA sells them too. Made for an F250/350 Dana 50, but it's the same thing. $20 or something.
