Auxillary Fuel Tank Install Instructions
Old 07-12-2007, 10:40 PM
Hemlockusa's Avatar
I have a 2005, 3500 dually, does anyone have ""INSTALL INSTRUCTIONS'" to help this old man install an auxillary fuel tank??????
I would sure appreciate the information. I know there has to be a step by step install instructions some where. Help me out Men. Moderators if I have put this in the wrong section, I am sorry. Please move it to the proper area and let me know where to find it.
Thanks John
Old 07-12-2007, 10:57 PM
8mpg's Avatar
what are you having trouble with? Basically just set the tank where you want it, mark the holes, drill them and bolt it down. Then drill a hole bigger than the hose or hard line from the tank through the bed. Then "T" into the fuel vent line (the 3/4" hose that attaches the filler neck)..
These trucks can be gravity fed because the gas cap is a sealing gas cap and will not leak. I suggest putting a ball valve in the bed so you can close the line on the tank.
Old 07-12-2007, 11:42 PM
dezeldog's Avatar
8mpg that is about the way that I have mine plumbed except I have a 2 mic racor FF between the aux tank and the main. No problems so far.
Jim
Old 07-13-2007, 02:50 PM
Hemlockusa's Avatar
No the instructions I am looking for would include pipeing through a pollack valve and switch on dash to change from one tank to the other, also wire auxillary tank into dash guage. I don't want gravity feed. Thanks guys I appreciate your assistance. Old John
TJE
12-10-2007 11:33 AM
Hemlockusa
07-31-2007 11:24 AM
TJE
10-25-2006 10:21 PM
kc8ksg
03-22-2006 11:46 AM
Ramblin Rebs
06-15-2005 08:18 PM
Quick Reply: Auxillary Fuel Tank Install Instructions
