Aux tank
Old 05-27-2007, 09:12 PM
kawiram's Avatar
Aux tank
Hey guys just got a super deal on a RDS 51 gallon tank box combo. Traded the guy for a toolbox I payed $50 bucks for. Looked at em on the net, and they are like $550. I'm stoked! Now for the question: I found this gravity feed setup from Northern. Is this a good method, (and legal), or should I fiddle with valves and pumps, yada yada yada? Click on accessories- http://www2.northerntool.com/product-1/200306719.htm
Old 05-28-2007, 09:46 AM
Oilguy's Avatar
I have had it both ways.... Gravity is by far the easiest method... for both installation and operation.
And it is cheaper....
OG
Old 05-28-2007, 12:56 PM
rbrettctd's Avatar
My cousin used to run one with a gravity flow. He was later told by a DPS trooper that it is illegal in Texas. Id check it out on the DOT site.
Old 05-28-2007, 02:13 PM
kawiram's Avatar
Another ? Im in the Navy, so Im stationed in TX, but my trucked is registered and tagged in NM. Do I need to go by NM DOT regs or TX?
Old 05-28-2007, 04:50 PM
rbrettctd's Avatar
Its not by where youre from. If TX DOT checks out your truck, they can ticket you for whatever breaks their laws. Its highly doubtful they would check that, but ya never know.
Old 05-28-2007, 05:26 PM
Deezel Nate's Avatar
I have never seen anything that says gravity feed from an aux tank is illegal for diesel fuel.
I have all the DOT regs for aux tanks at home too since that's what I used to setup the tank I built.
Old 05-28-2007, 05:35 PM
rbrettctd's Avatar
That was 5 years ago. Could have changed.
Old 05-28-2007, 06:25 PM
It is possible that Texas doesn't allow it, though when I did the research I didn't find anything that led me to believe that any state said no to it.
States having different laws is pretty frustrating for people that move around alot, like I do (military). It's also ridiculous to thing that a person traveling cross country needs to learn all the laws of each state he's passing though.
Even though you are registered in a specific state, you have to follow the laws of the state your driving in.
Old 05-28-2007, 08:51 PM
kawiram's Avatar
Any idea where to find this info? Ive searched numerous DOT and DMV sites for TX and NM and cant find squat. Thanks for the help.
Old 05-28-2007, 09:03 PM
rbrettctd's Avatar
Just email transferflo or another aux tank company and ask them.
Old 05-29-2007, 11:39 PM
There's some info here, some links and other info.
http://pirate4x4.com/forum/showthrea...=555848&page=2
Old 05-31-2007, 08:31 AM
92DuallyCTD's Avatar
Check this: http://www.transferflow.com/fuel_tank_regulations.html Directly from Transfer Flow Inc's website on refueling/gravity tanks on trucks. Two things to note: #7 under the 'Refueling Tank Information', and #2 under 'Miscellaneous Notes'. Disregard the 'outboard tank' sections, that should be for the frame-mounted tanks on big semi's. All their tanks/kits require a pump to be in place. My guess would be to incorporate a rollover shutoff valve not normally found in a gravity system. Probably why any state/federal DOT would frown on it. Hope that helps!
PRO-NRA
16
04-01-2008 12:13 PM
ramsport59
MDDTR #33
02-21-2008 04:15 PM
groran
03-19-2007 07:44 PM
2500CTD
02-27-2005 01:29 AM
waam
12-31-2002 06:55 AM
Quick Reply: Aux tank
