Aux. Fuel tank
Old 01-12-2008, 04:00 PM
Camper Man's Avatar
Aux. Fuel tank
I thinking of adding a aux. fuel tank to my Mega please post pro/con on: in the frame tanks or in the bed tanks. I would prefer to leave the bed open. With the 5th wheel hitch in and the trailer on I don't have much room.
Also is it possabile to hook the "in the bed tank to you exisisting tank so it drawn off of one tank. Any suggestions would be helpfull thanks in advance.
Old 01-12-2008, 05:50 PM
bluebull's Avatar
I've known some to hook their inbed tank to the main tank by running a line from the drain bung on the aux to the vent line on the main tank. Look inside your fender where the filler neck is, you will see 2 lines, the large one is the main fill the small one is the tank vent for while your filling the tank. Cut and put a T in that line to go to the drain bung.
You can buy fuel tanks on line or have a local welding shop make one for you to your specifications. This time of year they are looking for work and might give a better price, at least in my area that's the case.
A couple of places:
www.aerotanks.com
www.transfertanks.com
www.northerntool.com
www.transferfuel.com
Old 01-12-2008, 07:35 PM
djbikeman's Avatar
I believe it is illegal to connect an auxilary tank in to your main tank for 2 reasons. Aux tanks are not DOT approved as a transfer tank, and a gravity fed fuel system is illegal. If you want to do this, you need to look into a DOT approved transfer tank that controls the flow of fuel from the transfer tank to your OEM tank if this is the way you want to go.
Here is a link from Transfer Flow's website that outlines what is legal and the options you have:
http://www.transferflow.com/fuel_tan...l#Misc%20Notes
My advice for you is to look into a larger tank under the vehicle. There are tanks available in the 50-60 gallon range. You already mentioned the major con of an Aux tank - bed space.
silver_2000_tj
10-02-2009 04:31 PM
PRO-NRA
16
04-01-2008 12:13 PM
ramsport59
MDDTR #33
02-21-2008 04:15 PM
groran
03-19-2007 07:44 PM
2500CTD
02-27-2005 01:29 AM
Quick Reply: Aux. Fuel tank
