Autometer Pyro Tap - Jacobs Access Port?
Old 01-26-2008, 07:58 PM
Utundra's Avatar
Autometer Pyro Tap/Jacobs Access Port - Thread Size
My Autometer gauge pyrometer came with a 1/8" NPT with 1/4" compression for the pyro probe itself. The Jacobs brake is tapped with a 1/4" NPT.
Will I be be able to find at Home Depot a 1/4" NPT and 1/4" compression adapter to mount the pyro probe? Does it matter if it is brass?
Old 01-26-2008, 11:57 PM
Luvnacumns's Avatar
Do not use brass!!!
WHere at in Southern Idaho you located.. Im in Twin falls if your close I can help you...
Shane
Old 01-27-2008, 10:53 AM
Utundra's Avatar
Originally Posted by Luvnacumns
Do not use brass!!!
Shane
Why not brass?
Thanks for the offer, I moved to Utah, spaced out updating my profile.
Old 01-27-2008, 11:53 AM
Luvnacumns's Avatar
Why not brass?
I read on here that it can't handle the heat...
Old 01-27-2008, 12:53 PM
Utundra's Avatar
Home Depot had the right bushing, but only in brass. Any ideas where else to look?
Old 01-27-2008, 08:22 PM
Utundra's Avatar
Seems as though the ISSPRO gauges use brass to mount the thermocouple. They also come with a 1/4" NPT insert to mount the thermocouple.
Anyone know if the ISSPRO Type K thermocouple will work on an Autometer gauge?
This is not supposed to be this hard.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
Utundra
01-26-2008 10:16 PM
HOV
13
06-02-2007 10:33 PM
Hoss
04-11-2006 11:37 PM
Quick Reply: Autometer Pyro Tap - Jacobs Access Port?
